Question about Sport & Outdoor - Others
Fuji Industires Liquid-Cooled engine - 499cc
I purchased a 4 wheeler which has a Fuji Industires Liquid-Cooled 499cc engine. I have about 40 miles on the 4 wheeler. By the way, we have six 4 wheelers and have no problems with any of the others.
The problem I have is that the engine is extremely hard to start. It seems as if during the compression stroke the battery and starter are not strong enough to turn the engine. I have replaced the battery and starter with heavy duty units and it did not make any difference at all. The engine does not spin beyond the compression stroke without help.
The help I provide to start it is that when I connect a battery starter with a stronge start option and spray starting fluid into the carb intake I am able to get the engine to turn beyond the compression stroke and the engine starts easily.
Do you have any ideas or advise related the starting of the engine? I have asked the dealer that I bought the 4 wheeler and they said that the starter might be binding due to a problem with the starter shaft bushing. They instructed me to drill out the bushing .001 of an inch and the problem should go away. I did drill it our and it did not make any difference, it still does not turn beyond the compression stroke without help.
I loosened the cover that is over the starter and starting gears and attempted to start the engine and was able to get it to spin, however, to me it was dangerious because the cover was very loose.
Do you have any ideas? I was wondering if the starting gear shaft was a bit too long and is causing a binding problem. I have the equipment to adjust the length of the shaft but thought I would seek some advise before I do that.
Any ideas?
Thank you in advance for your response.
Bill Plazyk
Leesburg, VA.
SOURCE: problem with clutch and gear box of four stroke engine
what is the1st problem of the clutch?
Posted on Jul 01, 2008
  • 148 Answers
SOURCE: 1988 Yamaha 4 wheeler slow crank
put jumper cables from battery to starter directly
to see if it turns over faster put red on starter lead and black on gorund(metal housing)
You may want to try this from a car battery to see if it spins faster if it does it indicates a problem with power from new battery check cables and lines for power blead
Posted on Jan 04, 2009
  • 383 Answers
SOURCE: Little to no injector pulse only when starter is engaged
95-97 Maximas had a problem where condensation from the A/C would accumulate in the a/c evaporator case from the drain becoming restricted or blocked, When this would occur, condensation would drip onto the ECM and a problem would develop with misfire and/or starting. I would look at the ECM where the harness connects to it for corrosion problems. If you find it, there is a chemical spray which can be used to clean the terminals and/or you can clean them, although it is time consuming and difficult to due because of how small the terminals are. After things are cleaned up, lightly coat the connections with a dielectric grease. This will prevent electrolysis.I believe you can buy these at Radio shack and possibly at an automotive parts supplier.
Also a drop in voltage during the cranking phase will cause a weak spark. Your ignition is what pulses the injectors. It takes a minimum of 9.6 volts, but ideally you want at least 10.5 or more during the cranking phase if you want to get a spark worth anything. Check the voltage on the primary side of the coil while cranking the engine.
I'll watch to see if things work out for you, let me know. ....mybunkey
Posted on Apr 18, 2009
mhamlin63
  • 138 Answers
SOURCE: 1994 S10 Blazer Tahoe starting problems
Well, obviously someone didn't tell you the truth because spraying into intake doesn't make the vehicle turn over any better. You have ignition or fuel delivery problem. Start by taking fuel line off at intake and crank engine a couple times catching any gas in a cup or something. If none, then trace fuel line back and under vehicle til you find filter. Should be under driverside midway back on inside of frame. Change this and try test again. If no gas, see if fuel pump is on motor(mechanical pump). Change this and test again. If not on motor then it's in gas tank(electric pump). Most cases the tank has to be lowered to take out pump, careful not to drop, dent or make sparks. Some came with access through the floor so check that first. Normally you can hear an electric pump come on when you turn the key. Good Luck
Posted on Jun 30, 2009
  • 491 Answers
SOURCE: I have a yamaha trimoto 175 3 wheeler, The carb. Flooding!!
CHECK THAT THE NEEDEL IS NOT BENT AS IT HAS TO BE DEAD STRAIGHT .
Posted on Nov 08, 2009
What year and model suzuki 4 wheeler has serial number j412-112355. jug stamp 229cm3
have no idea at all what that is.
and ATV, if yes post to ATV section and not Cars.
and no question asked.
is it a year question?
is this a road car.
if yes, and in USA is it>
then the engine serial number has the year code
as does body VIN.
so. next time stated what the heck is a 4 wheeler.
suzuki makes many, that have 4 wheels.
the only thing with "JUG stamps" ive ever seen are
motorcycle engineS. (or ATV that many use same air cooled engine)
NO IDEA WHAT CAR, OR TRUCK
NO IDEA WHAT ENGINE,
NO IDEA WHAT YOU ARE ATTEMPTING TO DO.
229 CUBIC CENTI-METERS. CC'S
NO car has this, here.
Dec 28, 2015 | ATVs
How do u install a new fan belt on a 27hp lawnmower engine
need more info dude do mean drive belt as most are liquid cooled
Jul 01, 2014 | RTO 200cc Full Size Four Wheeler ATV
How do i replace a fan belt on a encore prowler lawn mower27hpengine
hay ya did you mean drive belt ? and is that the zero turn model only asking cos most of them are liquid cooled get back to me without fans sorry if this has wasted your time
2001 cbr f-y is it carb or injaction
Model: Honda CBR 600 F4 Year: 2000 Category: Sport Engine and transmission Displacement: 599.00 ccm (36.55 cubic inches) Engine type: 599cc, liquid-cooled, inline, four-cylinder, DOHC, four valves per cylinder Stroke: 4 Bore x Stroke: 67mm X 42.5mm Carburetion: Four 36.5 mm slanted flat-side CV Compression Ratio: 12.0:1 Power: 110.00 HP (80.3 kW)) @ 12500 RPM Torque: 68.00 Nm (6.9 kgf-m or 50.2 ft.lbs) @ 10500 RPM Starter: Electric (Digital transistorized, with 3D mapping) Cooling system: Liquid Gearbox: 6-speed Transmission type
final drive:
#525 O-ring sealed chain Physical measures Dry weight: 170.0 kg (374.8 pounds) Seat height: 810 mm (31.9 inches) Wheelbase: 1,395 mm (54.9 inches) Chassis and dimensions Front brakes: 296mm dual disc with four-piston calipers Rear brakes: 220mm single disc Tires Front tires: 120/70 ZR-17 radial Rear tires: 180/55-ZR-17 radial Speed and acceleration Quarter Mile Time: 11.00 seconds @ 124.65mph (199.44km/h) Top speed: 260.0 km/h (161.6 mph) Power/weight ratio: 0.6471 HP/kg Other specifications Fuel capacity: 18.00 litres (4.76 gallons) including 0.8 gal. Reserve Color options: Blue/red, black/yellow, black/dark gray
Apr 06, 2010 | 2000 Honda CBR 600 F(4)Y
I have a liquid cooled 4 stroke scooter. It runs
Check the cooling liquid qty. I feel engine piston is seizing. Replace the engine coolant as per the manufacture's recommendation.
Mar 29, 2010 | Yamaha YZ 250 F Motorcycles
Liquid cooled.
Water cooled engines allow for a much more compact construction and a defined cooling on a wider operation band.
And no. Water Cooling should not be disabled under any circumstands, except you want to kill the engine. It would be killed, even on the north pole.
Air cooled engines have a much simpler design and production costs, also much lighter usualy, But need a lot of space. Also the heat distribution can be challinging construtructive task.
Oil cooling is available for both cooling models, but usualy only with 4-stroke engines. It just adds more cooling to the engine
May 29, 2009 | 1998 Suzuki VZ 800 Marauder
Engine oil plugs?
Just oil,The same you run in the rest of the engine.
May 14, 2009 | 2004 Yamaha YZ 250 F
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
