Question about Saws
Dewalt 708 sliding compound mitre saw
Had this saw for about five years and have now noticed the blade wobbles slightly and snatches on occasions, its not the blade cuz i brought a new one and still no joy. any common problems or wear and tear you've heard of will be a great help. thanks in advance.
  • Anonymous Oct 23, 2008
    Same problem.  Haven't inspected the shaft yet.
  • Brian Johnson Nov 22, 2008
    My saw is 1 year old and started doing this. Taking it for repair tommorow. Will let you know what they find.
    Novelist:
  • 99 Answers
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Posted on Nov 01, 2008
I replaced the blade in the dewalt DW716 mitre, now the blade spins slow and trips my breaker??
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
http://servicenet.dewalt.com/
Best regards, --W/D--
Feb 07, 2011 | Dewalt DW716 15 Amp 12Inch DoubleBevel...
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
Jul 26, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
Hi my dewalt 708 lx sliding mitre saw, 110v, seems to only have half the power(speed) that it should have, and cannot cut timber on a compound cut because of this, any suggestions please.
I have heard complaints that this saw does not do well on angled cuts because of its low power. Try running a shorter and/or thicker extension cord and checking your input voltage. That's about all I can think of, hope it helps.
Mar 12, 2010 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Can't change mitre angle
you need to remove the guide fence with the screws on the back. then you remove the throat plate and there is the bolt is that keeps it all together.
Just took one apart last week, not really difficult
Dec 26, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
I lost my manual and need to adjust the bevel settings
Make sure its a compound mitre and not just a mitre saw. The check in the back for a round knob with degrees marks on it, theres your adjuster.
Sep 24, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Wobely blade
sounds like the bearing is going out on the blade shaft
Feb 10, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Dw705 12" mitersaw
I do not know your machine but from previous experience I know that a sircular saw blade wobbles when it was over heated during use.
Oct 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Saws Logo
1,050 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
