SATELLITE DISH I 'VE RECENTLY BEEN HAVING PROBLEMS WITH MY PICTURE ON TV.I MOVED MY SATELLITE DISH SLIGHTLY AND HAVE NO PICTURE NOW.CAN I FIX THIS PROBLEM MYSELF,WITH SOMEONE WATCHING THE TV SCREEN WHILE I MOVE THE DISH UNTIL I GET A PICTURE
  • 374 Answers
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Posted on Oct 07, 2008
To begin with I have Dish network my TV went off and since then in order to have picture and sound i have hookup HDMI cable and also video cable to have picture and sound
You need to set up the dish box for the correct resolution ie 720/1080 etc.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 05, 2017 | DISH Network Televison & Video
I have sound but no picture on my tv
This is a popular question. Most of the time you either need to make sure all connections are not loose or just need to turn off your tv and receiver and unplug. Wait for 1 minute then reboot.
I recommend this short video as it walks you through some diagnostics for other possible problems.
Repair TV With Sound But No Picture
Nov 24, 2015 | Luxor Televison & Video
Veon tv manual
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
This link says that your TV doesn't come with a Remote and DVD cannot be ejected without the remote :
VEON 19 LED TV DVD FREEVIEW COMBO A1823511 1
Jun 28, 2014 | Televison & Video
Troubleshooting tv
you need to buy tv converter box,
Jun 16, 2014 | Televison & Video
When CRT JVC TV is first turned on, the image looks shrunken and warped, eventually, the image looks fine. What to fix?
SMPS fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Check all the electrolytic capacitors.
May 26, 2014 | Televison & Video
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
I have a toshiba LED TV Model 40PB200, i bought it two months now. Recently, the audio in port started producing a sound as if microphone is on and the VGA for computer flickers when i connect a laptop on...
One thing is that unless it is usb you should always have the devices powered DOWN before connecting them via" wire electric data cables". it only takes 3 static volts of electricity to damage a circuit board. when you zap you buddy when you wear sox its 20 to 30,000 volts of static electricity so 3 volts would not be known let alone felt or seen. Power down and you will be well not you .
Sep 30, 2013 | Televison & Video
Lg ls5700 picture settings
you going to your setting option ,there having a display setting ,you set your picture.
Mar 26, 2013 | Televison & Video
My tv has gone some orange colour
Try unplugging your tv and anything connected to it - you might want to take a picture first so you have a reference. I would also unplug everything connected to the tv: cable, stereo, etc. Wait a few minutes, then plug in and re-connect everything.
You can also go into your TV's setup menu and adjust the picture settings - try restoring the default settings first.
Mar 22, 2013 | Televison & Video
I need an Owner's Manual for a Panasonic Sophia TV Model TC-21S80R2
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 16, 2012 | Televison & Video
Televison & Video Logo
183 people viewed this question
Top Televison & Video Experts
Electro Med Services...
