Question about Microsoft Xbox 360 Console
Xbox 360 ring of 4 red lights on the console
  • Anonymous Apr 12, 2009
    Ring of 4 red lights flashes when I attempt to start up console.
    Problem Solver:
  • 6 Answers
This is a problen with your av cable or your graphics card
any moreproblems email me at
omega_mods@hotmail.co.uk
Posted on Oct 09, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Upon turning on xbox 360 power light has a red circle
on the ring of light there are 4 lights
1 light = hardware malfunction
2 lights = overheating
3 light = RROD (red ring of death) your GPU has come loose
4 lights = a/v cable is loose/bad
Oct 22, 2010 | Microsoft Xbox 360 Console
I turn on my xbox 360 and it says go to
how many lights is it? 2 lights- http://support.microsoft.com/kb/907533?sd=xbox 3 lights- http://support.microsoft.com/kb/907534?sd=xbox 4 lights- http://support.microsoft.com/kb/906652?sd=xbox
Hope this helps!!
Jun 28, 2010 | Microsoft Xbox 360 Console
Red ring on console
As you didn’t state how many red lights are on your Xbox i will post all the Red ring of death errors.
All sections red (4 Red Lights) = Could not detect the AV cable. Check all of the cables at the back of the console.
3 Red lights (Sections 1, 3, 4) = General hardware failure. Contact Microsoft Support.
2 Red lights (Sections 1, 3) = Overheating. Make sure that your console is in a well-ventilated area with a good air flow and try again.
1 red light (Section 4)= Hardware failure. This is usually combined with an error code on screen. Contact Xbox support.
Nov 17, 2009 | Microsoft Xbox 360 Console
A red ring is around my xbox start up button
How may lights are showing up?
3 red light is GPU and the CPU overheating,
2 red lights is general overheating
1 red light is E74 and 4 red lights is the av cable.
For the 1, 2, 3, red lights you will need to get it fixed you can either send it in to do this or repair it yourself
Oct 26, 2009 | Microsoft Xbox 360 Console
Xbox 360 3 red lights can anyone please help?
That has absolutely nothing to do with the Hard drive. The red ring of death is a standard misfunction with the Xbox 360. You will have to contact your local game stores to see if they do Red ring of death fixes, send it in to microsoft, or attempt to red ring fix it yourself.
Dec 12, 2008 | Microsoft Xbox 360 Console
Xbox 360 2 rings
One red light signifies a major hardware failure or system error[4] , depending on which hardware failure or system error it is depends on how the problem can be fixed but in some cases there is no easy recovery and the console must be repaired or replaced. Two means the console is overheating and must be switched off and left to cool. Three, the infamous 'Red Ring of Death', means a general hardware failure and the console must be sent to Microsoft for repairs. All four red lights simply means that the console cannot detect its AV cable.
Nov 23, 2008 | Microsoft Xbox 360 Console
1 red light flashing
1 red light indicates that there is general hardware related problem with the console, 2 red lights indicate the overheating of the console, 3 red lights indicate the red ring of death and 4 red lights indicate that you need to tighten your AV console wire. If you get any of the problems and your system is under warranty, you can ship your console directly to Microsoft and you will get back your Xbox 360 red ring fixed by the manufacturer, however it might take more than a month and you will also have to bear the additional shipping charges. If your warranty period is over, you will have to pay additional amount of $140, if you choose to send the Xbox 360 to Microsoft for red ring fix. Further you will have to also bear the shipping amount and wait for at least a month for getting your console back. However, you can avoid this and can repair your console your own. There are many good guides available at Internet and you can go through any one of them and can fix Xbox 360 red ring problems your own.
Oct 22, 2008 | Microsoft Xbox 360 Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
4 red lights on the Ring of Light
The 4 flashing lights on the xbox 360 simply means that your A/V cable isnt securely plugged into either your console or your TV. Make sure these are really plugged in tight.
Apr 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
