I am stuck behind a firewall - Computers & Internet
  • 1,879 Answers
Which firewall ?
operating system ?
router ?
office ?
what are you trying to do ?
Posted on Oct 07, 2008
    Sergeant:
    Champion:
  • 334 Answers
Disbale windows firewall form control panel
How do i fix the blower stuck on high
if it only goes on high, the resistor needs to be changed . It is on firewall ,passenger side of car under wiper assembly behind alternator. not a hard job to do, part is not expensive. you will get low,med , and high back. if not switch on dash panel, or change blower motor, last ,since it is going on- working. good luck
Feb 22, 2015 | 2003 Chrysler Town & Country
How can I download purchased items on itunes (error 8003) from behind a Cisco RV220w firewall?
Configure the Cisco to "log everything", and then try the iTunes download. Then, examine the log-files, to see which connections were blocked. Then, configure the firewall to "allow" those TCP-ports.
Apr 23, 2014 | Cisco RV220W RV220W-A-K9-NA Wireless...
Heater hose busted on my 2001 Montana van
If it's a heater hose, it will go to the firewall behind engine, where it connects to the heater core's fitting that juts out from firewall. Hose goes over that fitting. Heater hoses are fairly easy to replace, maybe not so easy on yours, due to lack of space. Drain the coolant before taking off hose, loosen clamps on it, then start pulling it off. Watch for a hose holding bracket that also needs to be removed before hose is completely free. Some do, some don't have such a bracket. Hire a neighborhood kid that works on cars to replace it, as sometimes that hose to heater core fitting can get stuck on tight, and if one starts yanking or pulling on it, you can break the fitting and will then need a new heater core-big expense to replace. Good luck and merry christmas in capital letters, lol.
Dec 24, 2012 | 2001 Pontiac Montana
I have a l shaped house on my firewall as soon as i poor coolant in the overflow tank it runs out of this house
A hose on the firewall is usually a connection to the heater core behind the firewall (which provides cabin heat when the heater is on). If the hose is leaking, it's a simple and inexpensive procedure to replace it. If the leak is coming from BEHIND the firewall, the heater core probably has a leak and should be replaced.
Jul 06, 2011 | 1997 Pontiac Grand Am
Intake manifold runner control stuck open bank 1 where is this and how do i repair it
left rear of intake manifold, there should be a vacuum operated shaft that turns these throttle plates. You'll have to troubleshoot reason. Try turning shaft by hand. There is a vacuum switch that runs vacuum to both banks. I think it's behind the engine nearer the firewall.
Sep 01, 2010 | 2003 Ford Ranger Regular Cab
Location of ecm in 1995 lincoln towncar
Stuck thru the firewall on the drivers side below and to the right of the brake booster, looking from the front of the vehicle.
Jul 13, 2010 | 1995 Lincoln Town Car
Located drain tube and tried to clear it w/straw. Straw went in about 2" then stopped. Then whole tube came out of firewall. I stuck it back, but wonder if it's supposed to be attached to something inside...
mcdevito75 here, That"s the drain tube to the A/C evaporator, without it when you run your A/C you:ll have water on the floor on the passenger side. Re attacch that hose to the bottom of the evaporator under the glove box and then thru the firewall.
Jun 18, 2010 | 2006 Toyota Matrix
Crown victoria 95 brakes stuck how to fix problem
This is a 2 person fix. Check the brake fluid reservoir for proper level. Press the brake pedal and watch from engine area for pedal movement (or lack there of). Check brake cylinder behind firewall for corroded or broken lines. Fix problems accordingly.
Feb 16, 2010 | 1999 Ford Crown Victoria
Need help locating drain tube on 2003 mits eclipse
Look down the firewall on the drivers side, right behind the throttle body area.
About 18" down there is the end of the firewall insulation, fold it up and back and behind it you will see the drain tube (about 3/4") sticking through the firewall just above the steering rack.
Sep 13, 2009 | 2003 Mitsubishi Eclipse Coupe
I replaced the ac compressor in my 1999 Sebring convertible with one from a junk yard. The shop who replaced it said the valve must be stuck and is not opening(?) Can I fix this so my ac works or do I need...
if they are talking about the a/c expansion valve or h-valve,it could be stuck not allowing refrigerant flow..it can be replaced..it is located behind engine on passenger side at firewall..would recommend a professional to service your a/c system..this part may be available at your local parts dealer
Aug 15, 2009 | 1999 Chrysler Sebring
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
