I HAVE A DOLPHIN 1000 POWER SHOWER, IT'S QUITE OLD. CAN ONLY GET TEPID WATER. IF I TURN HOT UP FULL IT CUTS OUT. CAN YOU PLEASE HELP?
Get a new shower unit fitted of the same wattage.
CAL
Posted on Jul 27, 2011
Hot water in shower cuts outs quite alot
not enough hot water in the system
bleed the air out of the hot water tank so that it is full to the top by opening the pressure relief valve
Jun 29, 2016 | Water Water Heaters
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
I have to turn my shower to full temperature to get any heat out of it but when its on full the pressure is just trickle. I used to have it on number 5 but now number 5 just gives freezing cold water - any...
You have a blockage of the hot water coming to your shower head, or a blockage in the supply line coming to the shower head.
Be careful of the hot water in this procedure below.
Remove the head and try to clear the blockage from the head, as you have the shower head removed try to turn on the hot water to make sure you are getting a full stream of hot water to the shower head, if you do have a full stream coming to the shower head then the blockage is in the supply line coming to the shower head.
Please rate me
Dec 10, 2010 | Home
I turn on the spout for my tub and i turn the dial for my shower head to come on and it does, no problem, the shower head shoots water at full force, great water pressure, but there is still water coming...
I would look into the spout being the issue. The spout is a bypass when the shower is on and yours seems to be letting water get through. I would replace the spout..
Apr 27, 2010 | Price Pfister 01-311 Shower Head, Tub...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
Shower mixer taps
look for a scald safety screw adjustment. Remove the handle, and it is underneath. this is for safety of young children, and is factory set.
Dec 23, 2008 | Price Pfister Ashfield Single Control...
On demand, tank less water heater
THE WATER IS RECIRCULATING IN THE UNIT. MAYBE CAUSED BY THE ACID. TRY INSTALLING A BACK FLOW PREVENTER
Oct 25, 2008 | Water Heaters
Heating & Cooling Logo
576 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
