Question about Zenith E44W48LCD 44" Rear Projection HDTV
RU44SZ80L LCD Projection, triangular image in center of screen.
Triangular yeelowish blue image on screen when TV is on. Also seen durring black screen conditions. Probably LCD in Light engine. Can a kit be purchased to repair this? Light engiine is extreamly over priced new. I can send it in for repair for $325.00 still expensive and not necessary as I can repair this myself, just looking for a repair kit. What usually needs to be replaced for this king of a failure. Where can I get discrete parts?
Thank you.
SOURCE: Zenith 60'' LCD TV a blue screen is not sky blue it looks dark blue to black
ADVERTISEMENT/SOLICITATION FROM AN ATTORNEY REGARDING A LEGAL ACTION AGAINST ZENITH/LG If you are interested in speaking with an attorney at no cost and/or joining a class action lawsuit concerning the blue screen/haze problem on Zenith and LG rear projection LCD televisions, please contact Daniel E. Sobelsohn by phone or email: Daniel E. Sobelsohn, Esq. The Sobelsohn Law Firm 1901 Avenue of the Stars 2nd Floor Los Angeles, CA 90067 direct dial telephone (310) 461-1333 facsimile (310)861-5205 dsobelsohn@sobelsohnlaw.com
Posted on Oct 20, 2006
  • 121 Answers
SOURCE: lcd tv picture,on start up
is this a rear projection tv? a table top one? how old is it because if it's over a few years old, then it sounds as if the bulb may be going out but without having more info, it's hard to give an accurate advice.. please let me know if this helps..
Posted on Feb 27, 2008
  • 10 Answers
SOURCE: Sony WEGA LCD tv has
I had the same problem (w/o the blue specs). Sony extended the warrentee on this issue to the end of 2008. But hurry since I am not sure on that. They offered to fix it for free or sell me the latest flat panel ($2,500 at Best Buy) for $850. I took the flat screen since this problem will probably come back even after the fix. Also, they let you keep the old TV.
Posted on Oct 12, 2008
techman007
  • 1112 Answers
SOURCE: Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Posted on Sep 25, 2009
  • 556 Answers
SOURCE: I have a tv that is about 5 years old and the
iT IS THE LIGHT ENGINE AND IT WILL COST YOU MORE THAN IT IS WORTH. SORRY
Posted on Oct 07, 2009
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
Blue screen then goes black but still has audion HELP !!!
when it goes dark can you pull up tv menu if not or ch number take a flash light and press menu on side of tv or remote and shine light on the screen, look really close and if can see any images such as letters or number then very possible have a defective lcd panel
Jan 17, 2011 | Vizio VO420E 42 in. LCD TV
Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Apr 20, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 50inch DLP Hitachi that is 3 and a half years old. I replaced the bulb about 5 months ago now the blacks are blueish and it has a greenish blotch on the screen. It also leaves an image on the...
Contrary to popular belief, any display product can have "Image Retention" and even "Burn-In". This is true for Plasma, LCD, LCOS, DLP, and CRT. I do not see a model number provided, but I would bet that you have an LCD rear projection TV rather than a DLP projection TV. If this is the case, the Blueish and Greenish blotches you are seeing on the screen are the result of UV light damage. UV light will move heavily damage the Blue panel, due it's short wave length. So, bad Blue or Green (absence or Blue) is typically the the first visual indicator of a problem. Replacing the Light Engine will resolve the problem.
Mar 15, 2010 | Hitachi 43FDX01B TV
Blue diust specs constellation like!
If you are seeing the "spots" when a black screen is projected, the problem is likely to be scattering caused by dust on the lens. If you can get at both ends of the lens assembly, clean both sides using lens tissue. If the spots are seen at all times, there may be damage to one or more of the LCD panels.
Please update this with your results of the cleaning.
Thanks,
Dan
Feb 04, 2010 | Sanyo PLV-Z2 Multimedia Projector
Blue flashing power light only
kdavey53, "switch-mode-power-supply" for X193W is probably in shutdown mode due to having detected a FAULT CONDITION with itself or another circuit. Black screen = partial shutdown?? Black and Blank screen = full shutdown??? Which is it? Are you going to repair unit or use warranty? Have you seen video clips at youtube for "LCD monitor disassembly" and "LCD monitor repair" dealing with the most common black screen problem with ALL BRANDS of lcd displays? FYI visit www.ccl-la.com/badcaps.htm or www.badcaps.net or try wikipedia and search "capacitor plague" !!! Read more of my responses to other BLACK/BLANK screen owners for more options that you may have open to you. If not inclined to DIY repair, then have deep pocket$$! Your best shot and what I would do is buy new AND repair X193W to keep as working spare unit. Might only cost $10 in parts on a DIY. But you will need to do the research and understand the problem that you monitor is having. Do you understand what makes your screen "light-up"? Have you any of the new style "curlie-Q screw-in energy saving CFL light bulbs? Same basic principle! Just implemented in different way to produce RAW WHITE LIGHTon reverse side of what you been looking at. Look see only FYI www.ccfldirect.com and then you will know. I'm lmistyrel on aim or 12fixlouie on fixya Hope this was of some use.
Dec 14, 2009 | Acer X193W LCD Monitor
Yellow image produced by DP8200x
the light filter on the blue lcd is fried and needs to be replaced. it makes sure only blue light comes therough that lcd panel. when it's light is blocked from coming through, only the red and green lights can be seen, hence the yellowness (red light+green light=yellow light). it's common with lcd projectors. unfortunately, you can't buy that piece seperately. you need to buy the entire optical engine, which isn't cheap (almost $2000).
Jul 31, 2009 | ASK Proxima InFocus Projector lamp for...
TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Feb 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
Zenith E44W48LCD 44" Rear Projection HDTV Logo
109 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
