Question about Virtual Reality VRCD500-SDU CD Player
Error 13 MP3 playback
I installed this last year in my caravan, and it has worked fine until this summer, when all of a sudden I got the "Error 13" message when trying to use the SD memory card. I had changed nothing, the MP3 files are 128bit as recommended. What can I do? I have tried reformatting the SD card and re-laoding the MP3 files, but still nothing except the error message!
  • Alan Price Oct 08, 2008
    Thanks, sai. I'll try this
  • 1,512 Answers
Trouble with that one Eagle, "Taking it apart and rewiring will fix the issue.." probably just created a new set of concerns for the customer. I am sure that the phrase may roll off the tongue easily, but does constitute a rather novice solution particulary as he reports the problem as a card reader issue. Just what I am reading :)
Posted on Oct 08, 2008
  • 4,889 Answers
Ah.. Error13! Not again! Anyways this is a very common problem in all kinds of players that have USB support. Error 13 means device communication error usually due to power failure. Looks like some loose contact inside this player. Taking it apart and rewiring will fix the issue..
Hope this helps,
Sai.
  • eagle338
    eagle338 Oct 08, 2008
    Oops.. One of our experts has posted that by mistake.. It was intended to be posted in an experts' discussion..
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
My AC worked great until last year and then after a power steering hose leak was discovered, the ac until stopped blowing cold air. I took it and paid 75.00 to have it recharged with coolant and it worked...
My air conditioner started blowing hot air last summer. I put coolant in it and didn't run it until the beginning of summer this year (2011). All of a sudden it started working again. Sometimes it blows hot but if I keep it running full blast the coolness comes back. I don't know why this happened.
Jun 26, 2011 | 2004 Kia Optima
Runs fine until I engage the PTO and am on a slight incline.Starts to spit and sputter and cut off. Checked Plug Gap, Magneto Gap. Worked fine last summer. All I did this time was replace the blades....
check your fuel lines for clogging if it ran fine last year means you have a clogged fuel line somewhere or the carb itself is stopped up disassemble the carb and do a visual inspection also use B12 chemtool carb cleaner use both the spray and the fuel cleaner treatment i know for sure your problem is related to ethanol fuel hope this helps good luck and always run your equipment completely out of fuel for long term storage or between seasons
Apr 07, 2017 | Mtd Garden
Sound in camera not working
Have you found a solution to this problem? I'm having the same issue. Thanks.
millsj @ shaw. ca
Mar 29, 2009 | Panasonic SDR-H40 HDD Camcorder
''playback error'' message
There are MP3 files with problems, and when they are buried in the MP3, it causes the player to either skip, go to the end, or give an error.
Search for MP3VAL (it's on sourceforge, a free program) and it fixes broken MP3 files. It can do a whole directory very fast. It fixes file length problems in the headers, problems with the streams, and others. If the original MP3 file is badly mangled, you might end up with a "fixed" file that is missing some portions, but that's not created by MP3VAL (MP3 Validate).
See http://mp3val.sourceforge.net/
Mar 15, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Summertime Blues
This is the least of your concerns - change the battery again. The average life span of an mp3 player is less than 1 year. In 2009, consumer reports is finally going to come out with its reliability ratings, and mp3 players are going to fare worse than laptops which have a 43% failure rate in their first 3 years.
Aug 24, 2008 | Sony NW-E105 MP3 Player
Tape Playback
Try cleaning the tape heads with a DV tape cleaner and see if that works.
Jul 07, 2008 | Canon ZR800 Mini DV Digital Camcorder
Errorrrr
1 Press and hold the Play button while powering on your player.
2. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Dec 22, 2007 | Creative Labs ZEN SLEEK MP3 Player
No Cd playback
Dirt on the laser possibly Get hold of a laser cleaner kit and give it a go. Clean the CD Either of those two before getting worried
Jul 03, 2007 | Phase Linear UMP9020 CD Player
Virtual Reality VRCD500-SDU CD Player Logo
470 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
