Question about Sony BRAVIA KDL-40V3000 Television
Picture cut Just recently My picture is being cut off. I tried to adjust the widescreen, but everything I do doesnt help out at all. In fact it just gets worse. To add to it. Everytime I turn my TV on I get no audio. The only thing that fixes it is to turn it off and then on again..
  • 320 Answers
Sounds like a bad panel, although the audio problem is puzzling. When you say "cut off" is half the picture missing? A better description would help
Posted on Oct 18, 2008
Vertical and horizental picture expand and please help me to adjust it
It might help if you listed the brand and model of your TV, but usually on the remote you will see some sort of mode button. You can change the picture size there. Or you can go into your system menu and change it in the display menu. The typical ones are widescreen, zoom, stretch, etc. Also try changing the picture aspect ratio. 16:9 will give you widescreen while 4:3 will give you regular. Also, another problem might be that the channel you are watching or your cable box is not in HD. If the channel is not specifically an HD channel, the widescreen setting will not work properly and you will need to adjust it to a different setting to keep from getting the black bars on the side. Hope that helps.
Mar 16, 2011 | Televison & Video
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
Picture is cut off at the top and bottom of the screen - The top of the head is cut off and any writing on the bottom Help!
Look on your remote to see if you have a picture butto or you can try and go to the menu settings and see if you can adjust the tv format from widescreen to regular or 4:3 or 16:9
Sep 23, 2009 | Televison & Video
The picture does not fit the screen. The top and bottom of the picture go beyond the screen
you may need to adjust the aspect ratio of the picture, there is typically an "aspect" button on the remote that will adjust the picture from widescreen, super widescreen 16:9 ratio and sometimes you can zoom in. try that
Sep 20, 2009 | Samsung Televison & Video
The bottom and top of the picture are being cut off
Check your remote for a "zoom" or "picture size" button. Press this button to adjust the size until everything fits back on the screen.
Please take a moment to rate this solution a fixya if it's helped with your problem. Thanks for asking here!
Mar 21, 2009 | Vizio L32 32 in. LCD HDTV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Philips 42PF7320A cropping issue
Pete,
When using a hd connection on a philips tv and (I am assuming this is the case) the tv disables the format features on the tv and only lets you select widescreen and automatic, if you are using hd adjust the picture size from the cable/satellite box, look for it in the box's menu system or on the remote, it is usually labeled, aspect ratio, zoom, format or something to that nature, hope I helped you
Aug 20, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Mar 08, 2008 | Samsung LN-T4671F 46 in. LCD Television
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
No Red in the picture
Could be faulty red socket along w/ ballast. You need tech to see this.
Dec 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Sony BRAVIA KDL-40V3000 Television Logo
288 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
