Question about Packard Bell Computers & Internet
I have a packard bell computer - Imedia 1328, and have purchased a memory mod. 512MB DDR PC3200. How do I install it. IN easy step by step instructions for a silver surfer, please.
  • MalcolmBrigg Oct 08, 2008
    Thankyou debbily. I will try this tomorrow and will let you know if this old silversurfer is successful.
    Regards MalcolmBrigg
  • MalcolmBrigg Oct 10, 2008
    Hi debbily, Another question please. My E/Mail said you had a further responce to my problem. How do I find it on this page. You need lots of patience to deal with olduns like me! It is very kind of you to bother. Regards, MalcolmBrigg
  • 101 Answers
Assuming you bought the right memory chip...
power down the computer. Unplug the power cord from the case. You can leave the other cables attached as long as you have room to work. Open the case. There should be a couple of Phillips screws on the back edge to release the side panel. Once you can see inside the pc, you will see all sorts of cards and cables. Blow out any dust bunnies. Find the empty slot next to a card that looks just like the one you bought. Don't touch the metal contacts on the memory chip. Notice the notch on the edge of the chip and the matching notch in the empty slot on the computer. Gently, but firmly push the memory chip into the slot. It should give a little click.
Plug in the power cord, reboot computer.
Posted on Oct 07, 2008
Packard bell imedia 5064 specs
I currently have installed is Ati Radeon HD2400 AGP 256MB graphics card and im looking to upgrade it to this Sapphire Radeon HD3650 512MB AGP Graphics Card will it risk my computer to overheat, or is my computer not good enough to run such graphics card
May 21, 2014 | Packard Bell iMedia Computers & Internet
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
Hi Guys I have a packard bell istart 1359, memory max is 2048mb and I currently have 512mb installed. I purchased 2 x 1gb ddr2 pc2-5300 -cl=5 -unbuffered -non ecc ddr2 - 667-1.8v -128 meg from crutial. I...
some systems require ECC it may be as simple as obtaining ECC Ram......u can try checking the memory that cam with it to see whether it is buffered and ECC if it is you will have to obtain same type of RAM
Apr 15, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Try to install 2gb PC2700/DDR333 memory on MS-6741 motherboard
Hiya Luc
the problem is with your memory, i have read your post and b4 you was using pc3200 and now using pc2700 have you made sure that the memory is set to auto in the bios as it sounds like it is still set to ddr 400 and not ddr 333
regards Rik
Feb 26, 2009 | MSI K8MM-ILSR Motherboard
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Installed a new memory now computer won't boot up.
u just bought the wrong type of memory take the chip out of ur pc to best buy or a good computer store to help u buy the correct memory
Nov 24, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computer memory upgrade
Standard Memory 256 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC3200 DDR SDRAM DIMMs CPU Type 1.6GHz Intel Pentium 4 Model Comments 400MHz FSB
- Always believe HP - its there product - Staples is not the manufacture.
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
96 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
