Question about ' II' DIY Car Alarm Vehicle Anti-theft Alarm
Turn off with no reason
My alarm is repeatedly going off for no reason. Does anyone know what could be wrong with it?
  • prissy96 Dec 12, 2008
    My 2002 Ford Taurus's alarm goes off when you lock all the doors after about 10 min. Then it'll keep going off until you unlock at least 1 door.My 1998 Mustang GT also had the same problem.
Make sure all your door switches work for you interia lights also some alarm systems have a sound senser any sound like broken glass noise of passing cars or trucks and alike will trip the system. Check for loose conections
Posted on Oct 15, 2008
  • 1,861 Answers
My experience leads me to believe that the remote battery may be weak. Try replacing the battery and see if the condition is eliminated. this is the first thing that I would check if your vehicle was in my service department.
Posted on Oct 08, 2008
  • 104 Answers
You should consult a repair person to check your alarm.
Shooting in the dark is nice but not effective.
Posted on Oct 07, 2008
    Problem Solver:
  • 5 Answers
Minimiזe the risk of it going off first.
(1) Open and close the doors/boot/bonnet to make sure one isn't partly open.
(2) If there's a plunger switch for the bonnet then push that up and down a few times to maybe get rid of a dodgy connection.
(3) Press the recirculating air switch/lever with the engine on and make sure you hear it whirr into position.
(4) Close all face vents
(5) Turn the air direction switch to the feet/floor
Then try your alarm. It could be something simple like the sensitivity needing to be turned down or a faulty sensor.
Why is my '97 Mitsubishi Eclipse alarm going off?
Take off the inside door panel and see if there is something by the lock that activates/deactivates the alarm when you turn the key. Compare the drivers side(L), to the passenger side(R), that works. All mechanical things like to break down over time.
May 20, 2014 | Cars & Trucks
Sunfire alarm sounding for no reason
Focusing on switches: Start with the door switches. Pull the fuse for the dome lights. Reset the alarm. Does it sound off? The alarm feeds off the dome light fuse. Driver door is first: Often they wear out first and give us grief like this. Unscrew and disconnect the switch first. Replace the fuse. Carefully close the door so you don't loose the wire in the frame(attach a string to it so you can fish it back out if it falls in). Reset the alarm. Does it sound off or not? If it does, it is other than the switch or the passenger door switch (if a 2 door or 2 other passenger switches if a 4 door). Repeat process until the switch is found or all are eliminated. Switches are cheap, so replacing them will not break the bank. Disconnect the fuse again, unscrew the bad switch. Unplug it. Plug in the new. Screw it back in place. Reconnect the fuse and try it again. Repeat as needed until you have either found it or just limited your search area. Most often you will stumble upon it- chaffed wires, look plugs, bad switches). Yes, there is more, but I see this as the usual suspect. If you go back into the alarm, disconnect the alarm first, then observe the dome lights with the fuse in. It just may be a faulty control in the alarm, which is out of my territory. Let us know what you find, but start with the smallest things first. Good Luck!
Mar 31, 2014 | 2001 Pontiac Sunfire
My alarm keeps going off for no apparent reason, does anyone know why this is happening and if there is a cure
hood sensor switch. unplug it. done. won't make any difference to the operation of the alarm if its unplugged, it's just not in the alarm system anymore to cause a faulty alarm sound.
think about it though. car alarms are useless. so it goes off...big deal, whaddya going to do, shoot the guy breaking in. he's already armed. call the police? oh, by the time they get there...he's long gone.
Jun 02, 2010 | BMW 325 Cars & Trucks
The alarm clock on S5230 soemtimes work and sometimes it doesnot work, please help
Here's how you do it:
Menu--Alarms--Tap to create--Alarm Name and Alarm Time [the time you want the alarm to go off] (I'm sure you can fill that up)--Now here is the part where you are facing the issue--The Alarm Repeat--Now press the Week days Tab--Select Everyday if you want the alarm to repeat everyday or select alternate days--Click Save.
Now the alarm will go off according to your set schedule.
If you need more help on that do let me know.
Feb 07, 2010 | Samsung SGH-S5230 Cell Phone
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
I believe i can turn off my alarm temporarily(valet feature) on my 2003 honda element. does anyone know how?
I think it goes like this, but if I'm wrong, it is in the manual:
Hold the door open lever in open position and press the lock button at the same time. This will lock the car w/o the alarm activated.
Dec 09, 2008 | 2003 Honda Element
Alarm goes off at midnight & repeats for half hour, and not set
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
A better alarm clock
Use the datebook and you can make an alarm repeat any days you want.
Mar 27, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
' II' DIY Car Alarm Vehicle Anti-theft Alarm Logo
353 people viewed this question
Top Eagle Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Costanza
Thomas Costanza
Level 1 Expert
Are you an Eagle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
