Compaq Presario desktop computer HD LED not indicating activity
LED would indicate activity previously.Now only power LED functioning. Is this a sign my HD is about to walk out? I can hear the HD at boot up making the same usual sounds.
  • Stephen Wilkins
    Stephen Wilkins May 11, 2010
    Check to see if your ide pins are connected to the mother board inside the case. You could always download seatools for windows and check your Hard drive.
  • 285 Answers
The LED lights are usually connected separately to your mainboard, on the JFP1 pins. You could check your mainboard manual (if you have one) to see where it is on the mainboard. If the seatools say your HDD is good, you could unwire the JFP1 and try to connect a battery to the LED to see wether it still works. If it doesn't, it's probably one of the wires thats broken. You should, though, first check what voltage your LED is. If it's 0.5 and your battery is 1.5 you'll destroy the LED...
Hope this helps you solve the problem!
PS: don't go messing around in your mainboard without an antistatic wriststrap, or you might break it.
Posted on Oct 17, 2008
Green light is flashing in back of computer but it will not turn on
if the green light you're mentioning came from the power supply, you need to replace it. green light flashes from the LED at the back of the power supple serves as an indicator if you have a good or a faulty power supply.
Aug 07, 2010 | Compaq Presario 5000 PC Desktop
I have a Compaq Presario CQ60 laptop and was told that I had my scroll lock activated because the numbers on my number pad only half work. The 0, ., 4, 5, 6, /, *, - all work. The 1, 2, 3, enter, 7, 8,...
Find 'fn' key (this is short for function) then find 'num lock' key in your case it must be another key with and extra label with the same font color as 'fn', this means this key behaves differently when pressed with 'fn'. When you have located both key press fn+num lock a led indicating that numeric lock is activated should go off and you're done.
Mar 04, 2010 | HP Compaq Presario CQ60Z Notebook
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the...
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
May 28, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
No power
eh, did ya charge em?
May 12, 2009 | Compaq Presario Notebook
No Power, Cannot open
contact ur dealer..its hardware problem!
Dec 27, 2008 | Compaq Presario 700 470024-192 Notebook
Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
Nov 26, 2008 | HP Compaq Presario v3000z Notebook
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario SR1030NX fails to start
Sounds like the power supply or motherboard is biting the dust. U may consider power off, open case and clean out the dirt, check U'r connections and if the power supply smells, replace it.
Else replace the pc. When the power supply dies, it usually stresses the motherboard out and it dies later, sooner.
Jun 02, 2008 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Compaq Presario 700 won't power on
These are prone to broken power jacks that short out components on the mainboard. My shop saaw a lot of these come in dead like this and sometimes we could get them going again with a lot of mainboard work, but it seems they keep breaking.
I would save your money for another laptop considering the lousy reliability record these models have.
Dec 22, 2007 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
