Bosch Classixx 1200 won't drain. Any suggestions? Thanks!
  • Kaytie Jan 25, 2009
    I thought it was just our washer until I read this! I was just trying to source a new drawer but won't both if they're all like that. How can I sort this?
    President:
  • 1,462 Answers
Check filter and check no foreign objects stuck in pump impellor
Posted on Oct 08, 2008
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 It take in water then stop. I can drain it but it will not spin.
It looks like there could be a problem with a belt, maybe it sliped off, or maybe it broke, i would look that first
Nov 04, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
check your filter. Could be an eratic pump. Dispening draw needs to be cleaned and make sure the small hole is clear to allow the conditioner to flow through
Feb 26, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
