When i start up my laptop the screen loads then goes black , but you can still see the cursor but nothing else happens .. please help..
Try to clean up RAM's of Your PC or Laptop u can watch u Tube videos how to do it .. i Use Pencil Eraser to Do that... clean the rams put it back try it if its working ... if u have 2 or more RAM's try every piece one by one.. separately . if not .. try to open the Processor heat sink assembly . Blow it with air blower or compress air... to dust it off... if ur not a Professional plz dont do that ... Caution is required ... if u damage the Processor its not cheap .... Remove the Thermal Grease ... u can Apply WD 40 to do that .... wipe with cloth ... use fresh thermal grease put back processor and fix heat sink .... give it a try ... if the problem is still there clear the BioS setting by Jumper or Remove the Battery The Button cell .... wait for 2 minutes ... put it back ... if its still not working .... replace the Processor .... i hope u guys enjoy ur Hardware dont fed up... nothing is impossible ... Have a nice Day... ;)
Repair your Windows installation:
Note Repairing your Windows installation may change the configuration of Windows. You may also have to follow this step if you complete all the troubleshooting in steps option 1 and the problem is not resolved.
Follow the remaining steps to set up Windows.
Note You must have your 25-character product key to complete these steps.
As soon as this issue is resolved, make sure that the firewall is enabled, and then visit the following Microsoft Web site to reinstall the latest updates:
http://update.microsoft.com/
Hope this method works for you.
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
SOURCE: wont boot windows
Try to boot to F8 at startup if you see and boot menu you can restore the system or use last good known settings but you can only use last good known 1 time the results is what you seem to be talking aboutna cursor will be flashing indicating that the os has been wiped out or the drive is not functioning.if you have restore disk try to reinstall
