Question about Dell Inspiron 4000 Notebook
The fan on my Dell Inspiron 4000 is always running.
My laptop seems to always be running really hot and the fan is always on lately. It's driving me nuts because it sounds really loud. I'm not running a lot of crazy or CPU intensive programs (usually just iTunes and both browsers).
Is there anything I can do to cool down my Inspiron without just shutting it off altogether?
  • uberdiva Oct 08, 2008
    Thanks for the advice... I'll try running it in safemode to see if that helps... although I think you're on to something with the heatsink comment... that's easy enough to fix once I determine it's not background processes run amok!
    Thanks again!
    Novelist:
  • 137 Answers
A couple suggestions:
try starting in safe mode and see if it does it still. It could be that you have some background program like Windows update or that new Windows active search function, which spends copious amounts of processor time cataloging your entire computer. Some anti-virus programs will do the same and eat up processor time. I'd try shutting down as many of these background processes to see what (or what combination) is causing the problem.
If this doesn't work, you might have a bad connection with your heatsink, which would cause your computer to stay at or your fan might be going bad, causing it to get really loud.
I'm not going to go into the possibility of it being used on a lap or bed or carpet where the fan intake vent is getting blocked. I know you've eliminated this as a possibility. Right?
Posted on Oct 07, 2008
  • wingsinhisna
    wingsinhisna Mar 27, 2014
    Where do I go to find out if the windows active search function is going? I did download some windows updates I was told were needed.
  • Daniel Herd
    Daniel Herd Mar 27, 2014
    I'll assume you have the same problem, which you didn't mention. You might be lost and just looking for WAS function info. Anyway there should be an indicator in your notification bar that tells you it's indexing. Also in your task manager you should see it as a Process.
Driver for Windows ME for a INTEL WiFi PCI Card B2200BG WF03?
Try e-bay or a second hand shop. ME is unfortunately no longer supported by Microsoft
Jun 13, 2012 | Dell Inspiron 4000 Notebook
How to replace bad cooling fan on dell inspiron 1521 laptop
Replacing the fan is easy, once you remove the drives, the panels from the bottom, etc. Remove the keyboard and unscrew the frame. then the laptop clicks apart. The fan can be removed replaced.
While you can replace the fan fairly easily, they are expensive if you have to buy one from DELL. You might be able to substitute one from another laptop however.
The problem on the Dell Inspiron though is not the fan, but the design. It does not dissipate heat well, cycling heat poorly throughout the casing and ultimately over the drive before exiting from a primary vent on the side which needs to be higher to get good air flow. The air gets so hot and dirty that it eventually clogs up the fan and over heats the drive.
As a matter of fact, even when the fan is running normally the drive often fails anyway right around the two year mark. My last two companies have bought these and you can almost set your watch by the drive failures.
The solution, is a $5 cooling tray like cooks use for cookies. The metal grill will lift the laptop about 1.5 inches off the surface your working on and allow air to move freely in and out of the vent on the side.
Mar 08, 2010 | Dell Inspiron 1521 Notebook
My dell inspiron laptop runs very hot and is very noisy
The way i see it you have 2 solutions:
Either go to your retailer and get them to dust the laptop and clean it`s fans. (You didn`t specify if it`s still in warranty)
Or solution number 2 would be to buy a special support for laptops.. most have 2 or more fans incorporated so that u get more ventilation. Of course that will not solve the noise problem really..
You also didn't specify how long have u been using your laptop as... with age they of course degrade and there is really no solution for that.
Aug 06, 2009 | Dell Computers & Internet
Laptop Switches off and is really hot to touch
cooling fan not working.on the side of laptop see if the fan ventilation does not have dust covered.
Jun 29, 2009 | Dell Inspiron 5100 Notebook
Dell inspiron b120 laptop won't power up
i dont know why dell did this but you have to have battery to run your laptop. the ac coard charges the battery which runs the computer. I really know why but i dont like the configuration. it is so the power is clean to your computer and so the can have less parts in the laptop you need to get a new battery
Jun 23, 2009 | Dell Inspiron B120 Notebook
Replacing a fan
download
DELL INSPIRON 1525/1526 SERVICE MANUAL
here:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/sm.zip
on sysboard.htm
you´ll find the solution
May 07, 2009 | Dell Inspiron 1525 Laptop Jet Black
My dell inspiron 4100 cooling fan wont turn on
I would get a new fan. you can get a new fan and heatsink by clicking here
Really hope this helps you.
Dec 12, 2008 | Dell Inspiron 4100 Cooling Fan -...
Laptop running hot - Fan cycling on and off every 10-20 seconds
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
Jun 14, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron 4000 Notebook Logo
644 people viewed this question
Alun Cox
