Question about Saws
Jig saw the blades on my jig saw keep falling out,i have tightend them on the on the machine that has a screw to keep in place,with the other being spring loaded to hold the blade in position, but the both of them spit the blade out when i try to cut any thing can you tell me why, thanks.
    Champion:
  • 242 Answers
On the spring loaded one a metal pin will fit through a hole in the black to keep it in place. Ensure your blade is not broken and has a hole for the pin to go through.
Posted on Oct 24, 2008
What is the procedure in putting a blade in the scroll saw?
there are 2 methods of blade retention
1-- is a small screw in the side of the retainer that jams the blade in place
2--- the blade is held in place by a collet actio pull the blade shaft all the way back into the machine -- pull the retainer at the ed of the shaft back further up against the machine and the old blade will fall out -- put in the new blade and release the collet retainer
Jan 18, 2016 | Saws
How do I CHANGE A blade on a MASTER Mechanic variable speed Jig Saw PP/G30
most blades are held in with a collar if there is no hex screw obvious
pull the shaft all the way back up then pull the collar around the blade up further and the blade should fall out.
May 18, 2015 | Saws
How do I remove the blade that is stuck from a Craftsman jig saw with the easy release?
Hi Tom:
Don't know what caused it to get stuck, but my old Craftsman just has a spring loaded metal tab that holds the blade in place. Have you tried using a screw driver to gently pry the release? It shouldn't require brute force but a bit of gentle persuasion shouldn't hurt.
May 17, 2015 | Craftsman Saws
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
Jig saw blades wont stay in.
loosen it more before you put the blade in.
Mar 16, 2014 | Skil Saws
Just received a used Bosch B4200 jig saw and I can't figure out how to change the blade. This is the first bayonet style blade jig saw I've owned. I don't see a screw to release the blade.
If this is similar to mine, (sorry I don't recall the model number, but it's a GREAT saw!) there is a knob or lever on top of the handle that you pull up about 1/2 inch. Then you turn that handle 3 or 4 turns (counterclockwise) to unscrew the clamp holding the blade. When you do this you can't see anything happing, but the blade can then be pushed into the holder just a bit and twisted 90 degrees, then you can pull it out. Installation is the reverse. Don't overtighten the handle, just turn it clockwise until it stops, then back it up until it lines up with the handle and you can push it back down. Good luck, Please vote if you found this helpful.
Feb 16, 2011 | Garden
How do you put a blade in a hitachi cj110mv jigsaw
on the front of the saw where the blade is there is going to be a little lever you pull while at the same time push the blade in the blade holder
Jan 16, 2011 | Hitachi CJ110MV D Handle Jigsaw
Blade keeps falling out when jig saw is started?
ther could be an old peice of a broken blade stuck in the collar were you insert new blade
Oct 07, 2010 | Ridgid 26638 Saw R3121 Orbital Jigsaw
Blade keeps falling out. What am I doing wrong?
ive had this problem many times, first make sure you have the right blade, then you need to make sure you are seating it correctly, and tightening correctly.
Mar 31, 2010 | Dewalt 18 VOLT CORDLESS JIG SAW MODEL...
Saws Logo
476 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
