Question about Philips 60PP9352 60" Rear Projection Television
Read and Blue but no green
I have a phillips 60pp935217 tv. The picture is perfect except it has no green. removed the back and saw the left and right (red and blue) lenses were working, but there was no light coming from the center (green lens). Is the CRT the most likely problem and if so what is the part number for it? I looked around inside and didn't see any other obvious problems. Thank you in advance for your help.
salt56
  • 373 Answers
SOURCE: phillips magnavox 52" big screen rear projection t.v
I will say that you probably still have the clear liquid (Glycol) still on the board. I recommend cleaning with a degreaser spray and brush it off with a clean 1inch paint brush. You can get the spray at Radio Shack The glycol is hard to remove and is conductive to electricity.
Posted on Jan 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: Blue bulb emits light, but no picture.
Phillips have been known for the coolant to get contaminated especially in the blue CRT. it congeals and your picture will become hazy and out of focus.This is something you an do yourself. If youre careful. If you would like instructions on how to do this proceedure. Let me know.
Posted on Jan 21, 2008
Slinteriors
  • 8617 Answers
SOURCE: convergence problem on a Philips projection TV
They should be STK392-120 but check the numbers on yours to be positive. They are located on the extreme left of the chassis looking inside the back panel mounted on a heat sink. They will have STK Numbers stamped on them. Yes you should change both of them they cost 10.00 each at electronix.com You will need heat sink compound as well but this is better purchased at Radio Shack 2.00 per tube. Put a good coat of Heat sink compound on the back side of the new ICs. Also check over the resistors on the board next to the ICs sometimes 1 or 2 of those burn when the Cs go out. Let me know if you need anything further
Posted on Jan 25, 2008
Slinteriors
  • 8617 Answers
SOURCE: Phillips DPTV335 colors out of alignment
you need 2 Convergence ICs STK392-120 you can get them at this link and they provide free step by step instructions with free tech support so you can do the repairs yourself.
http://servicemanuals.vstore.ca/
Posted on Apr 05, 2008
  • 4 Answers
SOURCE: picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Posted on Apr 28, 2008
42C128135UA-52 Phillips Flat Screen TV. I switched it on and all i got was a clicking sound and flashing green LED light which continues 1 long flash 2 short flashes. No picture whatsoever.
On the lower right side of the psu, (clamped to a heatsink), i changed the 8.5v (L4940P85) voltage regulator and it worked. As a test to single out the fault i warmed this component with a fine blue flame, this would make also make the tv work perfectly.
Aug 29, 2011 | Televison & Video
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
My philips 60 inch 60pp935217 TV showing murky
If your saying the picture looks cloudy then the CRT fluids need to be replaced also known as projection tube coolant.In most cases only the blue and green CRT's need to be serviced.
Apr 30, 2009 | Televison & Video
Sony KDP57WS550 Projection tv red, green and blue virtical outlines on left and right sides
This is a convergence problem. You will need the stk's changed and a pico fuse or 2. also from looking at the pic you might want to clean the lenses and mirror after the repair to bring back some of the vibrant colors the set once had when it was new. This repair should run you anywhere from $300-$500 depending on your area and the tech that comes out. If you need more information or would like to try to fix it on your own please let me know.
Tim
Sep 10, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Picture color - it is a blue and green picture- no other color- looks artificial
Jan 18, 2008 | Philips 60PP9200D Television
Philips 60PP9352 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
