Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Hitachi hd 57 inch rear projection tv.
My tv has just recently started to look out of focus (dbl vision) and red seperating from other colors, is this an adjustment or does it need to be rerpaired?
thank you in advance for any help
  • 1 more comment
  • Anonymous Jan 24, 2009
    Hitachi 57f710 Rear Projection - dark background red is the predominate color.
  • starcraft49 Feb 01, 2009
    red is doube what part do i replace ????
  • loboone58 Mar 06, 2009
    my 57f500 rear proj. hdtv has the red out of line i even tried the magic focus auto @ it gave me a code #5 but wouldnt go thru the sequence so i tried to adjust manuely and the red would adjust verticle but horizontal it wouldnt adjust
How do you get the screen off? I took all the bolts out from the top and sides but can the the bottom to come off. I need to take the screen off because its got water inbetween the two screens...Any Help?
Posted on Jun 12, 2010
Well i need to know what to do i took the tv apart and ready to install new parts if i can know more ??????
Posted on Jan 31, 2009
    Scholar:
  • 92 Answers
You may be able to correct this problem with the convergence controls in the user menu. Hitachi also has on some projection sets a button called "magic focus" which is an automatic convergence control. If you can't seem to bring things back the way they should be you may have to get your convergence ICs replaced as well as some resistors in the convergence circuit. Unless you have above average soldering skills I'd suggest leaving that up to a technician.
Posted on Oct 07, 2008
I have a red X on screen of my Hitachi 57f510 HD tv. What does that mean?
It may have to do with the Magic focus if that model has it: auto convergence and if fails a indication can appear on screen. The Magic focus if in play would be a flashing sequence moving to different areas of the screen in sequence.
Dec 09, 2012 | Hitachi 57F510 57" Rear Projection...
My t.v.focus is like double vision and the color is not right.
convergence failure that tv has 3 CRTs-cathode ray tube- and it has a circuit that keeps each picture projected from the tubes aligned together called convergence. so if you have a picture that has 3 pictures of the same image in red green and blue then it is defintely a convergence failure. the part numbers of the parts causing the failure are STK394-160 and there also can be some burnt resistors in the same circuit.
Jan 06, 2011 | Hitachi 57F500 57" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
How to adjust the color on a HITACHI ultra vision HD
you have to hit the menue button, then go th the video section,,may say picture, dee if there is a reset in there, if not, put the color at 55, and make sure the tint is in the middle of red and green, aldo put it on Dynamic
Jan 11, 2009 | Hitachi 57F500 57" Rear Projection...
Color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Dec 28, 2008 | Hitachi 57F500 57" Rear Projection...
Magic focus, #5 Manual
Sounds like a Convergence IC problem, the convergence ics would need to be replaced. This can be done by yourself or a professional.
Jun 06, 2008 | Hitachi 57S500 57" Rear Projection...
Color issues on my Hitachi 57 inch rear projection
Your convergence ICs need to be replaced. You can get replacements at the following link and they provide free tech support as well as installation instructions so you can do the repair yourself. It takes about 45 minutes from start to finish.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Televison & Video
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Magnavox model 6P5440
You can turn up the Screen controls in back of set. Look for the focus block that has 6 controls on it. 3 are for the screen and 3 for the focus, in each color Red, Blue, Green. need to turn evenly to keep color balanced. On set turn color all the way down and then get a good black and white picture.
Sep 14, 2007 | Hitachi 57UWX20B 57" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
1,206 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
