Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
VERTICAL WHITE LINES
There are vertical white lines that will not go away
  • 1 more comment
  • abt188 Dec 08, 2008
    there are about 8 vertical lines acoss top of screen. Picture can be seen in back of lines. how is it fixed
  • Anonymous Dec 30, 2008
    I just noticed white vertical lines after I attached my xbox 360. It started after I hooked up the HDMI cable, do I need a xbox hdmi cable?
  • Anonymous Feb 19, 2009
    there's a white vertical line across my laptop computer screen. i dnt know how it got there or how to get rid of it
    Problem Solver:
  • 16 Answers
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Posted on Oct 24, 2008
4 Suggested Answers
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
SOURCE: White vertical line on left side of screen
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
projdoc
  • 2237 Answers
SOURCE: White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Posted on Dec 29, 2009
Why is there a white line across tv screen
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 13, 2014 | Sanyo DS32920 32" TV
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
One day my tv started having white lines in various places, then one day the scrren went white but still has a small line across the top that works fine
The problem is "Vertical Over-drive" and the white lines are vertical retrace lines. What has happened is a component failure between the vertical oscillator and the vertical driver circuit. The component is usually a capacitor that is leaking and allowing voltages to appear where they shouldn't be.problem component is leaking and allowing DC voltages to appear where they don't belong. It's causing the vertical driver transistor to run "flat out" and will ultimately burn out the transistor from internally generated heat.
Hope this help....
Jun 18, 2010 | Televison & Video
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
White lines at top of screen - can't make go away
You have a problem in the vertical output circuit. Check for bad capacitors around the vertical output IC. The value of these caps are marked on the side of them. Thanks for using fixya. Please take a moment and rate this responce.
Nov 30, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Vertical colored lines on white background on SyncMaster 740N
Hey dont open the LCD in a hurry......the problem may be due 2 usage of LCD 4 long time better dont on the pc for a day........or in night time keep it under the fan.......this may give a better result........
Nov 09, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
2,558 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
