Question about Sony KV-32S66 32" TV
KV-32s66 Flashing stby timer LED- no pic no sound
This set was running fine and just turned off. When powered back on the Stby timer LED flashes and power relay clicks on but that's it. Found Horiz output Q502 (2sc5148), MX0841 (IC601), (R607) .47 ohm fusible, and D648 B+ zener (EZ0150AV1) bad and replaced. All replaced and even swapped out Flyback without any luck. Suggestions would be appreciated.
  • 6 more comments
  • crabbybill Oct 07, 2008
    Flashing LED is a steady rate (i.e. not like an error code) just continuous flashing until power is turned off. The Power supply 'G' board appears fine (all voltages OK) and the 'A' board looks great and all semiconductors (except big IC's) check OK in circuit.
    Just went thru the serv manual and this unit doesn't have an IC301 but the led is a steady blinking
    Power board 'G' board and chassis board 'A' have been checked and rechecked for basic semiconductor and capacitor problems --nothing out of the ordinary.
    diodes and basic semi's check ok
  • crabbybill Oct 08, 2008
    What is 'G2' voltage? not familiar with that term. The set is essentially dead except for blinking LED. Just found a post on another site that states that a weak CRT can prevent IC001 from starting up
    Spent a couple hours checking out "c" and "a" board components with no luck. Checked the caps in the Horiz circuit again and semis check good. I adjusted the screen setting (G2 -learn something everyday)with no sign of startup. Something was taken out by or was caused the failure of the Horiz Output and power supply. I'm starting to think that IC351 (y/c jungle)may have been zapped--just running out of things to check.
    B+ and 9volt running low now -- checking semis again especially IC643 but may have a problem with T603 or T605 -- I'll be back
  • crabbybill Oct 09, 2008
    Found B+ low. Went out and got a 'real' Sony IC601 (MC0841B-F) and replaced it. Checked caps in the area. B+ still low at 60.6 vdc and the 9 volt line at 1.17vdc. Checked full wave bridge (D602) and it's OK along with caps C606 and C607. Removed T603 and T605 to see if any physical burns underneath etc--both look brand new, but continuity is the only thing that I know for sure. Any suggestions
    New Friend:
  • 74 Answers
Check c609-c612, also make sure you solder all the bad solder joints :)
Posted on Oct 09, 2008
  • 171 Answers
Your IK video path is defective,also check recheck IC601,R607
  • 10,594 Answers
I got all your post now and want to guide you further as follows...
Please check these parts on A board...
D356 on pin 36 of IC351 ( Y/C Jungle)
D521 near to IC501
Confirm +B volts at pin 2 of FBT and Collector of Q502
Confirm volts at Collector of Q501 (H-Drive)
I hope you have Service Manual of KV-32S66
Let me know out comes to help you more.
Thank you.
Posted on Oct 08, 2008
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 08, 2008
    T603 & T605 are ok in your tv.
    You can have +b volt and rest of supply voltage if Q648 collector is low. Its power / standby switch transistor. If tv is in protection mode, as your tv is, you will not get full +b
    Shahid Electronics Oct 09, 2008
    If you can't see my comments, can't help you.
    Shahid Electronics Oct 10, 2008
    hope you received solution email.
    Sergeant:
    Champion:
  • 334 Answers
I would cheak power suplly again test it even tho looks good may not have votage u need to fire it up
  • nick helpap
    nick helpap Oct 08, 2008
    if u just say votls running low then bad power one of rails not good enf just liek cmputer if my 3.3 v rusn at 2.9 computer dont run ok cheak power
  • 790 Answers
Hi
Check first the oscillation circuit! the problem is Power oscillation... check for open and shorted to the oscillation circuit!
Thanks!
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 08, 2008
    G2 Is a high voltage that is for Focus and Screen Supply Voltage! Very high voltage that is 1000 volts plus...
  • 4,234 Answers
THe continuous blink can indicate a low G2 voltage as well. Is there any sound at all or is the set essentially dead except for the blinking standby light?
Thanks,
Dan
Posted on Oct 07, 2008
  • 1 more comment
  • ABRsvcs Oct 08, 2008
    OK, these sets are known for having the CRTs go bad over time. Try the following:
    Open up the back and turn up the screen control on the flyback transformer a bit (clockwise). If the picture pops on, the CRT is likely to be going bad. This is only a temporary fix to buy you time to replace the set. Replaceing the CRT is an option, but not worth the expense.
    If the above does not resolve the problem, further measurements internally will need to be taken.
    Keep us posted.
    Dan
    Normally, if the jungle IC was the problem, the sound would continue to work OK. I have seen cases where the sound does not, but those are rare. IC351 is Sony part number 875208273 (CXA2095S).
    Keep us posted.
    Dan
  • ABRsvcs Oct 09, 2008
    IF the 9V line is only measuring 1+ volts, there is something on that line that is pulling the voltage down. Look for filter caps on the 9V line that are shorted or any ICs that are fed from this line that may be defective as well.
    Dan
    Genius:
  • 1,913 Answers
Check any diode regiser or transistor or any circuit are not blowup.also check power supply and earthing proper no circuit are ground that touch the ground.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Before we further think about solving the problem, what was the blink code or how many times did the Standby LED flashed ?
We need that code.
thanks, :)
  • Karthik P Oct 07, 2008
    Here are the standard definitions of Sony TV blink codes:
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • For more visit : http://www.agoraquest.com/viewtopic.php?...
    Scholar:
  • 116 Answers
Check for any short circuit on the board.
  • mastermind10 Oct 07, 2008
    and how many times the lights blink.
TV cannot turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Action-3: Replace the main board!!!
Mar 25, 2017 | Hitachi Televison & Video
My SB600 is on, shows "ready" but won't fire... the STBY shows on even when not connected to the camera. Will not fire. Any ideas?
Aug 17, 2010 | Nikon Speedlight SB-600 TTL Flash
The tv cycles on and off
dry soldering on EHT out put side horizontal SEXCTION
Jan 15, 2010 | Hitachi 55HDS69 55 in. Plasma Television
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Shows STBY
STBY means 'Standby'. This is to conserve the batteries. It will come out of standby mode as soon as you press the shutter release button halfway down.
May 29, 2009 | Nikon Speedlight SB-800 TTL Flash
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
No audio comes from the rear right speaker. what am i doing wrong with connecting the speaker on the htr-6130?
Swap the rear right speaker to rear left make sure the speakers and speakers wire are OK
Initializer the unit as follow set the unit in STBY mode if you are not sure which mode turn off the unit with the remote control now the unit is in STBY mode. Pressing STRAIGHT and AUDIO SELECT keys simultaneously then press power STBY button on front panel the display will show 1: Analog ByPass use the PROGRAM knob to move up to 13 PRESET INHI then press 1 or 2 keys to change to PRESET RSRV then turn off power now unit reset to factory just turn on and try it
Let me know how do you go
Cheers
PS: this model have an update firmware if your is still under warranty bring it back to Yamaha or 1 of the service center Yamaha they are able to update for you. Due to confidence I can not post that firmware sorry for that inconvenience
Nov 28, 2008 | Yamaha HTR-6130 Receiver
Sony KV-32S66 standby timer led flashes constant, slow; no picture
You could try touching a soldering iron to each joint, but if tv had perfect image before turning off, could be a bad flyback. Cheap part and easy repair BUT must know how to discharge any high voltage if any stored in capacitor of flyback. Might be a good repair to take in to have a pro fix it.
Apr 25, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-32S66 32" TV Logo
698 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
