Paper feed problem Canon PC25 copier
Copy quality is fine (even though this machine would qualify as vintage) Copy is drawn up and wrinkled as it feeds through the machine. Seems like it should be a simple solution. Can you help??
I don't know if there is a solution for your problem, I had the same trouble and wasn't able to find repair parts. Check the transfur rollers, mine had turned to mush and would cause the paper to go sidways and wrinkle. I was able to get some neopreme and make new roller tires, I have pictures if your interested. Mine now works well but in taking it apart I got the sequanceing out of step and it dosen't copy to the end of the page. About a inch and a half short. Finding someone that has worked on these copiers has been difficult, though they were very populer. Paul
Posted on Nov 23, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check where exactly it wrinkle .it is most likely to be from the fuser unite.i.e where the paper comes out .if the fuser rollers is having mark or the paper sepration finger ontop of the roller is bend or loses its springing ability
Posted on Oct 11, 2008
The paper keeps on getting wrinkled up every time i try to print it. How do I fix it?
It is possible there is some foreign material within the system specially stuck up in the rollers or the drive and so the feed of the paper tends to make the wrinkles.
Also the alignment of the ROLLERS must be clean so as to make the paper be drawn into in EQUAL force , if not the paper will move sideways and cause damage to the paper.
Aug 30, 2011 | Office Equipment & Supplies
Canon MF4370dn says "set paper
I can find no reference to this error but presume your paper is being drawn in then stops so you have to remove the toner to get the paper out.
What can happen on this model is the black plastic clip for the output tray falls off onto the paper and gets drawn into the paper feed area of the machine. it then jams the lifter and consequently stops the paper. Take out the toner and have a good look in the paper feed roller area to see if there is something stopping it.
repost if you still have the problem.
Jul 15, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
I have a Canon PC 980 B&W copier. When I try to print, the "P" (no paper) light comes on, even thoug the paper tray is full.n
YOur problem is likely worn feed rubber. It is an old machine. Has it ever been serviced?
Did this happen after a paper jam?
Try this: UNPLUG the copier Take out the paper tray. Prepare a dry cloth that is dampened with WD 40. Open the door on the right side of the coper. You should see 1 large, gray or black rubber roller. Gently wipe the roller with the WD 40 cloth, slowly turning the roller. It only turns 1 way, towards the exit direction of the paper from the copier.
Let the WD 40 soak in, about 10 minutes. Put the paper tray back in, plug the copier back in and try to make a copy. If it makes a copy, the feed roller needs replaced, If it doesn't make a copy, check the top sheet of paper in the tray. If you see skid marks, you definitely need a feed roller. No, they are not easy to change.
As long as the roller feeds, go for it. When it starts slipping then you'll have to do something about that feed roller.
Jan 24, 2011 | Canon PC-980 Color Copier
Paper jams when using the ADF. Canon IC D780
When using ADF
Note:
* Set a document on the Platen Glass if you want to scan it at optimum quality,
* The area (range) within 0.08"/2mm from the top edge if document cannot be printed since the machine cannot scan it.
*Do not load the following types of documents in the ADF. They will jam.
-Wrinkled or creased paper
- Curled paper
- Torn paper
- Paper with holes
- Carbon paper or carbon-backed paper
- Surface treated paper
- Onion skin or thin paper
- Photogragh or thick paper.
1) Remove any documents from the PLaten Glass.
2) Open the Document Tray.
3) Load the document in the ADF.
Load the document with the side you want to copy, or scan face up in the ADF.
4) Adjust the Doument Guides to match the document width.
Note :
Ensure that the edge of the document stack is in line with the Paper Size Mark imprinted on the Document Tray.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Nov 30, 2009 | Canon Office Equipment & Supplies
My copy is coming out wrinkled and threw the top slot by the rollers.where the normal copy would come out. Nothing is ****,paper is full,ink level reads green?? I just made a copy yesterday and it was...
There are about 4 possibilites. The paper in the drawer could have bent up corners, not laying in there good and flat, Fuser rollers bad or uneven spring pressure, something could be wrapped around registration roller or something in the paper path is catching the paper as it goes through the copier. Please rate this. Thanks
Jul 01, 2009 | Canon Office Equipment & Supplies
Canon faxphone L170 won't copy
if you look at the top piece of paper in the cassette is there a smug mark or wrinkle in the paper. you my just need to clean the feed roller. ( black or gray roller ) . I'm not sher on this model if it is a rear paper feed or a cassette from under if it is a back feed one look in side the paper shoot of any fourn object is in there. Hope for the best.
Feb 02, 2009 | Canon FAXPHONE L80 Laser
CANNON NP1215 COPY MACHINE
Coiincidence ??? E000 is a fuser error
Sep 25, 2008 | Canon imageRUNNER 1023iF Black and White...
Paper jam, paper not feeding
you might want to figure out how the paper flows through the printer. Sets of rollers move the paper up, down, down, and up check from where the paper starts in and around to where it ends it might just be one piece of paper crumbled up very small somewhere lodged in the rollers.
-Daniel.
Nov 19, 2007 | Office Equipment & Supplies
Printing and faxing more than one page at a time
Hi This is a common problem, not only with your printer, but most at some time or other. In part it seems you get what you pay for, in that if you buy premium paper (business grade 40 mil), you normally have less problems. The paper is drawn into the printer by a rubber or compacted foam roller, and sometimes the paper sheets will sick to each other, and more than one will be drawn in. The best thing to do if you are using less expensive paper, or even the expensive stuff, is to "fan" the stack of paper several times with your thumb, at the end that will face the rollers, and also don't let the stack get down to only 3 or 4 sheets, as the problem is worse near the bottom of the stack. Hope this helps. Good Luck!
Nov 30, 2006 | HP OfficeJet 6110xi All-In-One Thermal...
109 people viewed this question
k24674
jasbo
jasbo
