Oven does not work at all - blue lights flashing on convection bake & broiler - also door does not lock and it is 120 volts on the power inside the oven -
SOURCE: electrolux built in wall oven,
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine,
fan works fine, but the oven will not heat regardless of the mode
(broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
SOURCE: broiler works but oven does not work on bake or
The problem you have is that the ignitor is bad that lights the burner for the oven. You will need to replace it.
Check out this tip that I wrote a bout this...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
SOURCE: Loud pop when I was baking with the oven on Convection bake
Did you resolve the problem with your stove.
Mine just did the same thing.
Hey Troy, I understand that you are having problems with your Electrolux Dual-fuel Range. Have you recently installed the range or had a power outage? When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
