Question about Frigidaire GLER642A Electric Dryer
Frigidare dryer the electric pannel works but the dryer wont turn i turned it manually few times , thenit started working, whats wrong with it?
    President:
  • 1,462 Answers
If it strarted turning when you gave it a push by hand, then the motor capacitor is faulty - cheap part
Posted on Oct 08, 2008
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
Frigidare electric dryer about a year ad a half old. When start button is pushed all lights on right side flash and unit beeps. Dryer does not run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Electric Dryer
My Kenmore 62602 electric dryer stopped working mid cycle and now wont start back up. can you suggest a few working sloutions?
It is probably the heat sensor, it turns off the machine if it gets too hot. You will most likely have to replace this or bypass it. It should show you where it is in the manual or the electrical schematic that comes with the washer
May 04, 2011 | Kenmore 62602 Electric Dryer
Drum occasionally will not turn unless manually turned a few times before start; can here a thud each time manually turned.
I beleive the start capacitor is faulty & it has dropped away from where it's supposed to mount inside,the capacitor is probably dangling down,hanging by it's wires & banging on the drum as it rotates.The start capasitor gives the motor it's first kick start to get goin & it's not working that's why you have to help by turning the drum.
Jun 04, 2010 | Whirlpool LER4634J Electric Dryer
Dryer won't turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
Electrical issue...220 dryer outlet problem
ok start at the pannel is there a double breaker there
usually a 30 amp two pole breaker this is how a pannel works first breaker pulls 120 off of one side of pannel second breaker pulls off 120 off the other side of pannel if you look the buss bars you will see that they interchange from one side of the pannel to the other so at the breaker you are checking make sure you have 120 v on output of one half of breaker and 120 on second half of breaker when you use a volt meter put one side to gng the other side to wire comming out of breaker you should have 120 on both sides if not you have a bad or tripped breaker
Apr 24, 2010 | Hammering
WONT DRY,DRUM WONT TURN
This sounds like the motor that drive the drum has packed it in could be the capacitor or the centrifugal switch cant say with the amount of info given. I am quite sure it is with the motor as manually turning it is assisting with the start up of the motor
Aug 18, 2009 | GE Profile Harmony DPGT750EC Electric...
Plug dryer in wall wont start
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Jul 28, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Ge electric dryer light blew out and now the dryer wont turn on
Apparently you had a short on the case. I'd look at that cord again. 3-wire is Black on right, Red on left, Green in center.
Mar 26, 2008 | Dryers
Frigidaire GLER642A Electric Dryer Logo
88 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
