Question about Sceptre DCL9a
How to turn off burn-in mode if botton on Monitor
I am trying follow the steps below, I can't turn the monitor off because the powerbutton would not response, so I pull the monitor power plug off, then try to follow steps again, nothing happen. Please help!
Turn the monitor off
* Hold down the Menu button and the plus button
* While holding the other two down, press the power button. Wait for the DVI connector graphic to disappear
* Release all buttons
* Press the minus button. The Service Menu should appear
* Scroll down to Burnin Mode using the minus button
* Press the Menu button to activate that setting
* Press the minus button to set it to Off (it should be blue when selected)
* Press the plus button to highlight Exit Menu
* Press the Menu button After over 6months of the computer been turned off(split up and had to move out) I recently reconected it. The computer seems to boot up ok but I have nothing on my screen. Now this blue box with "BURN IN MODE" has appeared. I can't get rid and can't use my comp. :-(
  • 2 more comments
  • Francois Dec 16, 2008
    I held down the menu button for appr. 5 seconds and it went into burn in mode. I can't figure how to get it out of this mode. While holding down any other button, the power button does nothing.also the only way I can turn off the monitor is to plug in the power button while holding down the power button.
  • fftprivate Feb 18, 2009
    I tried to do the above solution to the problem, but every time i got to the menu, after about 2 seconds would go "no signal" and then go to the "Burn-In Mode". It has worked on other computers though, just when its not plugged into one or on the comp i want it to work on, it does this.
  • meow meow Apr 30, 2013
    MEOW SAME
  • Leo Poole
    Leo Poole Dec 22, 2016
    I wish this would work for me but my monitor only has 1, 2, up, and down button help! email me: lman4723@gmail.com
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Posted on Feb 15, 2009
    New Friend:
Got monitor out of burn in mode by unplugging the power to monitor then while holding down the power button on monitor plugged in the power cord to the monitor all while it was connected to a running computer. Was able to turn the monitor off with the power button. When I pressed the power again the burn in mode was gone and the monitor was displaying what was on the laptop computer.
Posted on Dec 29, 2013
SOURCE:
My HP A735W is turning on but stays in power save mode and no key board or mouse function
I think the issue is your monitor. If the monitor constantly says Power Save Mode and not let anything else display then the monitor might be bad. See if we can isolate the problem by the steps below.
Try booting up in Safe Mode and see if the monitor works ok.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it works ok in safe mode then the monitor is ok and we might have an issue with a setting.
Try connecting another monitor to your computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor works ok, then your original monitor is bad. If the Borrowed monitor does the same thing as your original monitor then the issue is with the computer (possibly the video card).
May 20, 2012 | HP Pavilion a735w (PL308AAR) PC Desktop
Why is that I turn on my computer and my monitor goes straight to sleep mode? every time i turn on my computer the monitor does turn on, it goes into sleep mode. how do I fix this problem?
RIGHT CLICK ON DESKTOP There select "Click" the Properties.
And follow the step that are shown below: 3b34f9e.jpg
9145b0e.jpg On the "Turn off Monitor: option" there Select Never than press OK to accept.
Hope it may be helpful to you.
All the Best!
Oct 16, 2010 | HP Computers & Internet
Hp g60t went into hibernation last friday it wouldn't come out of hibernation so i had to hold in the power button and shut down. laptop turns on but no video now the screen stays black. i tried a reset...
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Further, if the issue persists after performing the above steps, then the issue could be due to hardware malfunction of the video card or defective LCD display screen of the notebook. Hence, I recommend you to connect an external monitor to the notebook and then check whether the display works fine on external monitor or not.
Step 3: External Monitor
You can follow the steps listed below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
I believe the information provided would be helpful to isolate the issue with your notebook.
Jun 07, 2010 | HP G60t Notebook
Why won;t my laptop power up
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
This will discharge the static charges from the notebook. Now check if the notebook works fine or not. However, if the notebook turns on and if the display stays blank then connect an external monitor to the notebook and check for the display on it.
Step 2: External Monitor
You can follow the steps below to connect an external monitor to the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
Incase, if the notebook does not turn on at all then the issue is due to internal hardware malfunction. In all the cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then I suggest you to contact HP support to get the notebook repaired under warranty.
Jun 02, 2010 | HP Pavilion dv9000z Notebook
Monitor does not come on when laptop is switched on
This issue could be due to presence of static charges on the notebook or hardware malfunction of the display screen or defective video card on the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists, then connect an external monitor to the notebook and check for the issue on it.
If your notebook is covered under the HP warranty, then I would suggest you to contact HP to get the notebook repaired under warranty from HP.
Jun 01, 2010 | HP Pavilion dv9000z Notebook
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
My hp notebook dv2201ca power on by itself, but lc...
Hi, to isolate the issue perform the following.
Step 1: Hard Reset
Step 2 :External Monitor
May 20, 2010 | HP Pavilion dv6000z Notebook
I have hp dv6500 i update my bios and my display is total black just light blinking pls help me wht i do ?
This could be due to hardware malfunction of the video card on the notebook. To isolate this, perform the following steps.
*** Hard Reset ***
After performing the above step, if the issue persists, then connect an external monitor to the notebook and check if the display comes on external monitor or not.
*** External Monitor ***
My LCD monitor goes off
Hi , Follow the below steps.
1. Right click on the desktop and click Properties.
2. Click ScreenSaver + below you will find Power Click on that
3. You will see Settings for Home/Office Desk power scheme and in Turn off Monitor slect Never and click Apply.
Thats it it will not go in sleep mode
Jan 11, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Sceptre DCL9a Logo
10,577 people viewed this question
Top Sceptre Computers & Internet Experts
Ben Slimene Aymen
Ben Slimene Aymen
Arnie Burke
Arnie Burke
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
