Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire Model#FEFL79GQA Freestanding Electric smooth topConvection Range
Bought this a year ago from Lowes..when i went to use front and back left burners i heard and saw sparks from left side of control panel...my son accidently used the left back burner the other day and it started a small but short lasting fire (stopped as soon as it was turned to off position). i am trying to see if there are any recalls or if anyone else has had a similar problem with this oven...or any solutions on how to fix it..the oven works fine and right burners are ok as well. NO HELP FROM FRIGIDAIRE
3 Suggested Answers
gasman44
  • 83 Answers
SOURCE: my gas frigidaire oven is working, but the top
It sounds like you have a faulty solenoid on your FSD (Flame Safeguard Device) This should,when working correctly, allow a small amount of gas through to the burner, if faulty no gas will come through despite being turned on at the control.
It's quite a fiddly job and i would highly recommend a 'Gas Safe' engineer take a look at it for you.
I hope this helps.
Posted on Jul 08, 2009
  • 574 Answers
SOURCE: My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Posted on Aug 24, 2009
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Burner element broken
Hi friarjp - I am happy to assist you. First, I will need your model number to better address the issue at hand. With this information I can verify which part you need exactly. Is it the right, left, back or front burner element or are you referring to the bake and/or broiler element.
Jan 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire Electric Range with Self-Cleaning feature, however when I start the clean cycle and set for 3 hrs, the display says thtat the range needs to lock, however the lock does not move, any...
its probebly a bad latch motor. not easy to get at. you may call for service.its located behind the back pannel but depeding on the model its hard to fish it twards the front to replace it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Replace clock on range
there is screw on back of range. remove screw and pull of back cover. that will expose clock. make sure you unplug unit first. don't forget where wires/plugs go
Jun 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Glass cracked on smooth top stove would like to know if I can replace it myself model #FEF366DSB Frigidaire
Usually short instructions come with the glass. Just be careful about the wires not to pinch them tween the new glass and the frame. Use the type sealant they recommend.
Mar 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
60 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
