This sounds like a common Camry problem. After driving my vehicle for about 20 minutes in highway traffic, the vehicle has difficulty idling when I slow down behind another car or turn a corner. This quickly deteriorates and then the car actually stalls when I slow right down or turn a corner.
Then usually the car starts again right away, but when I slow down again, stalls. Then when I start it up again, usually in traffic, I can’t get the shift into Drive. If I allow it to sit engine off for 3 – 5 minutes, it starts again, the shift can slide into shift, and the car goess off again, like nothing happened.
Until the next time, which is usually the following day.
You have one of two very common problems.
Number one may be a stuck open EGR valve
Number two would be a failing Idle Air Control valve (IAC).
Try this: Open the hood & locate the EGR valve, close to the firewall, behind the intake. Find & take with you a small hammer. The next time that it happens, open the hood & tap on the EGR valve. If it is sticking "open" the tapping may dislodge the carbon particles that are keeping it open.When the EGR valve is open, exhaust is getting into the intake at idle, and this will def stall out the car.
There is no repair to the IAC valve, it would need to be replaced if it is bad.
One of these two scenarios will cure your problem, I see it every day.
rpms seem to be higher than usual when first started too?
car stalls when you slow down
I have a 2009 E90 318i efficeint dynamincs with start stop, which randomly cuts out usually when comming to a stop at traffic lights, revs seems to drop so low the car can not sat started, sometimes they drop low but pick backup, I have no fault codes on the vehicle, so not sure what the issue is.
