Kenmore 80 series heavy duty super capacity washer-new in 2002
Hope someone can help me here. I've had problems with my washing machine agitator going through a set of the dog ears every two weeks to a month for the past year and a half.
The guy at the parts store told me I was over loading my washing machine and wearing them out which is total balony! Been doing laundry for 30 years and I DO know NOT to over load a washing machine.
It's gotten to where I'm replacing the dog ears every two weeks now and the machine has also started to quit after the washing cycle has gotten to the last spin cycle and doesn't finish the final spin. If anyone has any suggestions on what the problem may be I would be most appreciative!!
Thank you
  • 943 Answers
HI colleen. thanks for the question. i know that you have been doing laundry for 30 yrs. i have been repairing for 45 years. they did not have daugs then. so the problem was not there. yes overloading is the cause . but if it wont go into the spin cycle . that could be the lid switch.
Posted on Oct 07, 2008
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
