Home | Motherboards | M2N-SLI Deluxe mot...
Motherboards
Problem for Motherboards
Generic problem for all Motherboards
M2N-SLI Deluxe motherboard won't boot
By donhug on Oct 07, 2008
System began periodic crashing after installing Vista Ultimate 64 bit. I thought this might be normal, but now it won't boot at all.
Best Solution
posted on Oct 07, 2008
Helpful)
admin734
Rank: Guru
Rating: 86%, 151 votes
This is what I would recommend doing to figure out whats going on:
Open the computer and run the mother board with only the necessary hardware. For example disconnect the cd drives , remove all the RAM except for one chip. See if that has any affect on the system starting.
Your description says its not booting, I am not sure if you mean booting as in to Windows , or booting as in not even powering up. If it is not powering up verify that the power supply is functioning (if you don't have a tester swap it out with another power supply).
There are a couple of other things you can do...below I inserted a flow chart for that. This diagram is great to follow for hardware issue's....I would definitely give that a try!
Also like I said above , by your description of " wont boot at all " I am assuming you mean hardware....if you were implying that Windows was not booting up , please let me know so I cna asist you further.....hope this helps straighten up your issue!
Comments:
Oct 07, 2008
- Sorry. didn't relize the image would come out so small! Here is the link to view it full size:
http://www.freewebs.com/fixing-computers/Chart_3.gif
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Hi, Are you sure that I can switch to the E5300, someone answered me that my board only supports... (More)
Answer
BIOS not "matching" CPU? Whaaaaa? This Medion is 5 years old, 6 if you take it from date... (More)
Answer
had root canal saturday tooth chips sunday
Answer
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motherboards:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14745
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
