I can see the apple logo, but the ipod will not switch on ?
Have you switched the small button on at the top of the i pod.we didnt even know there was a lock button there until our granddaughter told us.hope this helps
Posted on Oct 07, 2008
I just turned my ipod off and now it wont switch on and i am trying to charge it right now(i pressed the home key and the power key and it just turned black)
Can you see the apple logo or just black screen?
If only black screemn, it means you entered DFU mode. To get out of it, press home and sleep buttons for exactly 10 seconds until the apple logo appears.
Is this iPod jailbroken? If you're stuck on the apple logo, you need Redsnow to boot tether your iPod.
If you're still having problems, your last resort is to restore the iPod which means all your data will be erased. But try the first two suggestions first. Let me know if this works for you. :)
Mar 17, 2011 | Apple iPod touch
On the ipod 20gb after apple logo comes then bettry logo comes
Reset Click Wheel Ipod (newer ipods including resetting an ipod video)
1. Flip the Hold switch on and off and make sure it ends up no longer on hold.
2. Press and hold the Menu and Select buttons (center Button) until the Apple logo appears (may take 5-11 seconds, and you may need to repeat this step)
If this not work for you try plugging your ipod into computer or wall power
Resetting iPod (with dock connector)
Most problems with iPod can be solved by resetting it.
To reset iPod:
1 Connect iPod to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Play/Pause and Menu buttons for at least 5 seconds, until the
Apple logo appears.
If Your iPod Won't Turn On or Respond
* Make sure the Hold switch is off.
* If you're using the iPod Remote, make sure the remotes Hold switch is off.
* If that doesn't work, connect iPod to the iPod Power Adapter and connect the
adapter to a working electrical outlet. Your iPod battery may need to be recharged.
Resetting iPod (with out dock connector)
If that doesn't work, your iPod may need to be reset.While the iPod
is connected to power, press and hold the Play and Menu buttons
for at least 5 seconds, until the Apple logo appears.
Mar 03, 2011 | Apple iPod classic MP3 Player
Froozen and wont do ANYTHING
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    • utting iPods with a Click Wheel into disk mode
      1. Before placing the iPod into disk mode, you should verify that it is charged.
      2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
      3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
      4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
      5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
      If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
      If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 05, 2010 | Apple iPod nano
Ipod froze request me to go to www.apple.com/support/ipod
There are three reset variations for ipod's, depending on how old they are:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds.
Or:
  2. Press and hold the Menu and Middle buttons until the Apple logo appears, about 6 to 10 seconds.
Or:
  2. Press and hold the Play/Pause and Menu buttons until the Apple/iPod logo appears, about 6 to 10 seconds.
I hope that helps.
Dec 30, 2009 | Apple Audio Players & Recorders
When i got done chrging my ipod it froze
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
Resolution If you experience any of the above issues, try the following steps:
Dec 17, 2009 | Apple iPod Photo MP3 Player
80g ipod video. screen has ipod logo and screen
hold the select and menu buttons until the apple logo shows up, then quickly switch to holding the select and play buttons, this should put it into "disk mode." plug into itunes and click restore.
Nov 16, 2009 | Apple iPod MA446LL/A MP3 Player
Apple ipod won't switch on,
slide hold switch on and off a couple of times and when hold is in off position,press and hold menu and center buttons till an apple logo appears on screen.now connect to itunes and restore...
if apple logo doesnt come up,try the procedure a couple of times...if it still doesnt come up,you will need to take it to a service station.
Sep 07, 2009 | Apple iPod classic MP3 Player
My screen is on language selection and does not let me scroll or anything i think its frozen.
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My ipod nano is stuck on language selection and is frozen can you help me?
    Hope i helped you.
Thanks.
My ipod nano has frozen
  1. Toggle the Hold switch. To do this, slide the switch toHold (an orange bar appears) and then slide it back (orange bar ishidden).
    • Ifthe Apple logo appears on the display, connect the iPod to a computerand verify that it appears in iTunes and can play music. If the iPodappears in iTunes and can play music, no further troubleshooting isneeded.
    • If the Apple logo does not appear or the iPodis not seen in iTunes, connect the iPod to a power source by eitherplugging it into an Apple iPod USB Power Adapter or directly into acomputer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer is not set to sleep, standby, or hibernate.
  4. Afterthe iPod has charged for at least 20 minutes and while it is stillconnected to the power source, toggle the Hold switch again as in step1.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, the iPod should be serviced.
Jul 28, 2009 | Apple iPod nano 3rd Generation
35 people viewed this question
 Grubhead
Grubhead
