Question about Dryers
Kenmore gas drier does not heat up
Model #97581200 stock #75812 serial# md0801432
The drier starts up, but the gas burner does not turn on and provide heat for drying
  • gfmorris03 Oct 10, 2008
    Docjohn. Just wanted to let you know that your advice is right on the mark.Thank you.gfmorris03
  • Anonymous Mar 25, 2014
    GE model DBSR453GBOWW
  • 943 Answers
HI .Thanks for the question. the problem you have is with a thermal fuse, located at the ,of the dryer. pull away from the .remove the back panel. clean all the lint in the dryer. and the vent to the outside. the thermal fuse is located on the air duct. on the left bottom. of air vent a small plastic piece with 2 small blue wires. replace this part. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 07, 2008
I own a Kenmore clothes dryer, serial #ME2475807, model/stock #96573220. Recently the heat stopped working. It still spins the clothes around, but does not heat up to dry them properly. I think it needs a...
Unplug the dryer and take the back off
The backsides is where the element is located.
The back side components look like this:
Their are 2 limits mounted on the heater chamber:
More here
Sep 12, 2011 | Kenmore Dryers
110 74202200 Gas Drier will not heat.Blower works, Drum Turns, Vents all clear. Checked Gas line Gas getting to Drier. Looked at burner: It is clean, no rust, no corrosion, Wires in good shape. It appears...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 31, 2011 | Kenmore Dryers
Gas......starts to heat then quits minutes later.
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
Part number 279834 replaces for most models.
May 15, 2009 | Kenmore 62602 Electric Dryer
No heat when the drier is turned on
Sounds like a bad igniter (cause's a spark that inturn lights the burner) if when you start the drier does it make a ticking sound, if not, replace the igniter, if it does then it may be a bad gas valve, not releasing gas, if so, replace the gas valve. Or it could a bad switch not allowing power to get to your componets. if so replace the start switch.
Jan 31, 2009 | Kenmore 22422 Top Load Washer
Dryer wont spin
Take the back off  of the drier after unplugging and the beklt goes from the motor pully all the way around outside of the the drum.You can't miss it. Most of the Kenmore drier belts are the same. WE have apliance repair parts stores locally.If you also do , go to the store with the old belt and match it up.
Dec 19, 2008 | Kenmore 63942 Dryer
Kenmore front load washer won't heat
The gas burner assembly uses solenoid coils in a circuit with the flame sensor to safely ignite the burner. When the dryer starts a heated cycle, the circuit through those components is energized. The igniter glows until it reaches the proper temperature to ignite the gas, at which point the flame sensor trips open and the current flowing through that circuit is diverted to the gas valve coils so the gas valves open, and the burner lights and continues to burn. If the solenoid coils on the gas valves fail, the gas valves won't open for ignition. If the gas valve coils are weak, the burner lights during the initial ignition sequence from a cold start but it fails to light the burner on subsequent ignition attempts. In this situation, replace the valve coils. I Had the same problem with mine and I fixed for like $25.00 US. Its not hard to do look at the video. Either buy your part from them or to get it fast and not out of this world go to "repairclinic.com
Nov 17, 2017 | Dryers
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Cycles but no heat
The igniter needs to be near the burner jet in order to get a flame started when gas is provided,, the thermo fuse should be situated on the heat duct. I do not have access to Kenmore service manuals to provide any specific darwing details.. my comments are based on other brands.. I hope this helps..
Aug 30, 2008 | Kenmore Dryers
Dryers Logo
177 people viewed this question
Top Dryers Experts
