Question about Acer AL1916W 19" LCD Monitor
Monitor power light flashing and no display
When I turn on my computer, my monitor wont show any display, just black, and the power light keeps flashing in the pattern "orange, green, orange off. orange, green, orange off." But after like around 15 - 30 minutes the display finally turns on, then its back to normal. This always happens when I turn my computer on for the first time the next morning. My monitor brand is Acer, my video card is ATI Radeon HD 4200 and I'm running Windows 7. By the way, the monitor is 4 years old. Would there be anything wrong with video card? I hope not. Tell me what I have to replace, repair etc. If you guys can help me, it'd be really appreciated. Thanks.
    Top Expert:
  • Acer Master
  • 52,442 Answers
Failing power supply
Posted on Apr 02, 2017
SOURCE:
micromega69
SOURCE: Won't turn off and cylces through colors
Hi. This evening, I had the exactly the same symptom. I found a way to fix it.
When you power up the screen, keep the power and auto buttons both pressed. That seems to reset the screen. After that when you open the menu, a small F appears on the left side of the contrast icon. Go to that red F with the arrows and press menu. Another menu will popup. Choose 'Burnin' and set it to off. That's all !
Note: do not try to change other settings, they depends of the harware...
Posted on Dec 10, 2007
Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
bammbammfran
  • 159 Answers
SOURCE: RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
paulbtorrent
  • 34 Answers
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
Posted on Feb 08, 2010
Monitor flashes logo and then turns black.with red lights on
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 07, 2014 | LG Flatron Computers & Internet
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
My samsung Tablet's Screen keeps flickering continously
Here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 07, 2014 | Computers & Internet
My Acer Aspire 5551-2036 wont turn on blue light turns on screen remains black
Does it sound like the laptop booted up except the screen is black? Do you hear the fan running and the hard drive spinning? If so try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 06, 2012 | Computers & Internet
Monitor will not turn on
Monitor will not turn on as in NO Power? When you hit the Power Button the monitor power light does not come on? If so either the power cord is not plugged in good, maybe the outlet you have it plugged into the wall or power strip is not working, or the Monitor is bad and needs to be replaced.
If you are saying the monitor has power but the display is black then:
Look to see if it sounds like the computer is running but nothing is shown on the screen. If so try this:
Apr 06, 2012 | Toshiba Satellite P35-S611 Notebook
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Power light and screen keeps flashing on and off. No picture just a black screen.
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | Dell E153FP 15" LCD Monitor
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
No Image on Monitor Westinghouse L2046NV
well i just had this problem this morning i woke up turned on the monitor and it came on but went out. but i soon found out it was not the display that is not coming on its the black light. if you look closely you can see the display but there is no light to light it up so you can see. it doesent seem to be anything wrong with the circuit board just the black light i am going to be taking the monitor apart to see if there is anything me or any of you can do for the monitor to fix it.
Jul 26, 2008 | Westinghouse L2046NV Monitor
Acer AL1916W 19" LCD Monitor Logo
944 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
