Question about Denon Audio Players & Recorders
Denon AVR-3105 Unit tries to come on but after a few seconds power LED flashes red. (Unit shuts down) I found transistors Q1015L and Q1035L in the output circuit shorted. However, replacing these transistors had no effect on the symptom. The unit still shuts down. I don't have any other transistors in the output circuit shorted. Where should I go next?
  • 4,234 Answers
Look for open resistors in the same area. Also, if the transistors that you replaced are the output transistors, you should replace their compliments as well. I don't have the service manual with me at the moment, so I'm juist giving you generalities. If you can, lift the center pin of the output transistors and measure (and post) the voltage readings on each of three pads for each transistor. That should give me enough info to guide you further.
Thanks,
Dan
Posted on Oct 07, 2008
I have a Denon 1708 receiver. When I push the "on" button, either on the unit itself or using the remote, the light flashes green for a few seconds, then flashes red. When it turns red, all of the info...
Your result indicates the unit is not passing its power up self test. The first thing to try would be to remove all connections to the unit and try to power up. If it still mis-behaves, the unit has an internal problem best left to pros unless you're pretty good digging through circuitry. If it comes up stable, then reconnect things one at a time until the issue occurs again. Detach the offending connection and look for issues in the cables or the connected unit.
Oct 23, 2010 | Denon AVR-1708 Receiver
I have a Denon AVR 1509 and when I turn the power on it flashed green but after about 2 seconds it cuts out and and then flashed red every 0.5 seconds.
Usually its the power output stage . You can visibly check it if theres a burned resistor on the output amplifier. On the base of the Power output transistor if the voltage is the same as the collector pin it will indicate a shorted power amplifier circuit.
May 20, 2010 | Denon AVR-1508 Receiver
Unit keeps shutting off
Protection circuit activating. Possibly a shorted amplifier channel or power supply fault. Take it to a Denon repairer
Jun 02, 2009 | Denon AVR-1804 Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Denon AVR881 Turns on for few seconds then shuts OFF
(Probably too late to help you, but I'll post so others can see)
I had the same thing happen to my trust AVR-881 two weeks ago. Even re-initializing the processor was no help.
I took it to the repair shop. They replaced three transistors on the board, and charged about $175 for the job.
Apr 25, 2009 | Denon AVR-881 5.1 Channels Receiver
Power Button Flashing Red
Check to make sure the +/- speaker output wires aren't touching. I've had this problem before with frayed speaker wire strands poking out & intermittently shorting to the other polarity speaker output. This amazing receiver actually continued to play at low volume levels, but if I turned it up it would shut down similar to how you are reporting. I cleaned up the frayed wires & this fixed thr problem. Good luck
Mar 02, 2008 | Denon AVR-2105 Receiver
Power on problem
Time for a little repair here. It seems that one or more channels have developed an excessive drain on the supply, and has caused the threshold to trip and shut you down. It's more than likely shop time at this point....accordianman
Sep 03, 2007 | Denon AVR-2106 Receiver
Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Sep 06, 2006 | Denon AVR-1603 Receiver
263 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
