Question about Canon DR 3080C Path-Through Scanner
Canon Dr3080c is there a way to remove the pre scan window?
  • sday634 Oct 08, 2008
    i still need a solution
I need to find a service manual that will help me replace the roller kiton our Canon DR-3080C
Posted on Oct 16, 2008
Have mx510/512 canon printer/scanner/fax with new windows 10 computer. How do I scan documents or photo into my pc? no scan option when I open canon utility...
Step Connect the all-in-one printer to your computer through the provided USB power cable. Install all drivers that came with the Canon product. Without the drivers the computer is unable to import scanned images to your system.
Step Power on the printer and lift the cover on the top of the scanner bed. Position the image face down on the scanner glass, positioned in the corner when a green arrow points. Close the lid to secure the image.
Step Click the "Start" button, then choose "All Programs," "Accessories" and select "Scanner and Camera Wizard." This is a pre-installed application found on all Windows based computers.
Step Choose the "Scan" option, then select the connected Canon all-in-one printer and click "Scan" again. The image is scanned into your computer with a display of the picture on the screen.
Step Click "File" in the upper left corner of the desktop, followed by "Save." A save window appears on the screen. Title the image, choose a location to save the file to and click "OK." The image file now saves to your computer.
Aug 27, 2017 | Canon Office Equipment & Supplies
I have a canon doc scanner dr3080c When scanning on duplex ,the second page always has 2 parallel lines down it . I have looked to see if there is any dirt on the glass but there isnt What could it be
The dirt may not be visible, pls use Isopropyl Alcohol to clean the Glass surface. Don't use any solvents. For absolute emergencies, you can take aftershave/cologne on a cotton swab and clean the glass, ensure that plastic parts are not touched!
S. Mohan.
Apr 27, 2011 | Canon Office Equipment & Supplies
I have a Canon MP600 Multifunctional printer / scanner, the printer works fine, but the scanner sends a message, "Can not connect with scanner check cable and / or the scanner is switched on" I...
Hi I found one solution through Google. See if it works.
I had the same problem: suddenly the scanner took ages to calibrate/warm up. Turns out it had to do with the upgrade to Leopard or one of the updates (I'm on 10.5.7).
I downloaded the newest OSX scanner driver from Canon:
Now it scans without delay. Could have saved myself a lot of waiting a lot earlier!
Saving scans:
I always scan from the MP Navigator instead of from the scanner itself, so I can pre-edit the scans and save as .jpg to the folder I want and/or as a .pdf. Works for me....
Jan 04, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon DR3080C pafcv2.dll load error
Check that the feed switch actuator is not trapped below the feed bed.
Blow out the interior of the scanner with canned air.
Dec 03, 2009 | Canon DR-9080C Path-Through Scanner
How do u enlarge on scan mode
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Jul 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canoscan LIDE 25 using Vuescsan software
The first scan is 'pre-scan' and the second one is the real scan. The pre-scan shows you a rough image and you can check borders etc. Look for options and switch off 'Pre-scan' S. Mohan, India
Jun 03, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Communication problem with a MP210 Canon Pixma
Yes! No WIA, no scanning! It means Windows Image Aquisition is not turned on... Not only will the scanner not work but also other Imaging devices like cameras. The best way to find out will be to try and scan from Microsoft Paint. Go to Start, all programs, accessories then look for paint. When paint opens, click file then from scanners or cameras. Try to scan, if it scans then WIA is ok.
It means is the scanner software that was not installed correctly so uninstall reinstall just the scanner software! If Paint does not scan, then its your computer's Operating system (winxp) at fault. Make sure WIA is started, or better try to restart that service (in control panel, administrative tools, services, look for Windows Image Aquisition, restart the service).
Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
This is all due to driver compatibility issue,please thry this,first remove all software n drivers for the scanner ,download driver from this site by selecting ur operating system,n install,do remember to reboot ur laptop after removing previous software.
do revert
thnx N
Jan 26, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
The Canon support site is the place to go for that if your Manual does not tell you.
However remove the software and reload it - it may be as simple as that.
Dec 26, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Canon DR 3080C Path-Through Scanner Logo
223 people viewed this question
old marine
old marine
