Question about Bushnell Sportsman 4x32 Riflescope (4x32 mm)
How do u reset a rifle scope - Bushnell Sportsman 4x32 Riflescope (4x32 mm)
Hi type into Google, Zeroing a Telescopic Rifle site, Shooters have there own ways of doing it but you will find what is best for you depending on what type of rifle you will be using. If you are fitting it to a Air Rifle. You could Type in Zeroing telescopic site for Air Rifles.
Hope this helps
Posted on Oct 07, 2008
Zeroing telescopic site for air rifles
Posted on Mar 21, 2009
  • 5,568 Answers
Scopes are equipped with two adjustments; one for the vertical, one for the horizontal.
They move the cross hairs to bring the junction of the two into agreement with the bore of your weapon.
They are concealed under threaded caps that keep the adjustments protected from dirt or disturbance.
We have a number of different firearms and purchased this kit that includes arbors for about every common caliber of rifle:
http://www.gunsatcost.com/item/30586_Bushnell_Sights_and_Lasers_BUSH_744001___15-ARBOR_ST.aspx
We paid only $30 for our set on sale so I wouldn’t buy the first one you see offered so do your own search using the model number: BUS 744001
We have been very pleased with the results obtainable and it sure cuts down on the number of rounds normally required for ‘shooting in’ an unfamiliar weapon.
How do i mount my 650 laser sight to my bone collector rifle.
Red Laser Sight 650nm Weaver rail mount - Gamo USA
www.gamousa.com > Optics > Airgun Lasers and Lights
650nm Red Laser Sight with Weaver style rail mount.
Gamo airgun accessories, spare parts and products ' Gamo ...
www.gamousa.com/category.aspx?catID=4
Air Rifle Scope Mounts/Rails. Air Rifle Scope Mounts/Rails. Air Rifle Sights. Replaceable sights for air rifles. Air Rifle Spare Parts. Replaceable parts for air rifles.
Dec 25, 2015 | Laser Optics
1. HOW TO READ SCALING OF SCOPE.? 2. What is
You have not provided enough information for us to help you. What type of rifle? What do you mean by scaling?
With the scope on 3 power you should be able to sight it in at 25 meters. Going to a higher magnification may cause blurring at that distance.
You also may have mounting problems that are causing the scope to move around when you shoot. Your rifle may be fine.
Oct 09, 2010 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Reset to factory settings
Yes it is the same, it has the same barrel inside as a cross hair only you have a red dot. So just like you said, count the clicks and take it half way. You could do it with a vice, put a target up at 20 or 25 yards, depending on the pistol, lock it in a vice, shoot the gun a few times, and then put the cross hairs, dot, on the group, then you can fine tune from there. Check it out. And the bent barrel rifle, I had to stand on a barrel once to straighten it, actually I was jumping up and down on it, but I got it straight.
May 19, 2010 | Tasco 1x30mm Red Dot Scope With Matte...
How to reset to zero a Tasco RF3- 7X20 Scope? I am having prblems centering this scope Thank You
Making sure it is correctly fitted to the rifle, you Bore sight it. Best to put it into a vice using a thick piece of blanket to protect the rifle. Looking through the bore you line it up on an object about 10 to 20 meters away. Then you adjust the scope to fix the crosshairs on that same object. This will get you approximately on target. Depending on what a where you are going to shoot, assuming you are using a rimfire rifle, You then set up a target about 30 to 35 meters away. And adjust your scope to center on this target. That will give you dead aim at 30 meters and again at 90 meters, with only a slight variation in height in the middle.
Feb 04, 2010 | Tasco RF37X20D 3-7x20 Rimfire Riflescope -...
Need the rubber eyegaurd for a Bushnell Sportview rifle scope
if you need the rubber eye guard for this rifle scope you are using it all wrong,,,if your eye is so close to the end bell of the scope your going to get a very black eye,,,there is at least 2 inches of eye releaf on this scope so there is no reson to have a rubber bit on the end at all, i have 3 of the bushnell scops on my rifles a ,,,7.62,, .303,,,22.250 and none have the rubber on them,,,so far iv never had a black eye!
Nov 15, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
Cant determine if my tasco 6x24x42 scope was made before 9/02. rifle was dropped and can not get it sighted in. is there a fee to get it repaired!! I some other name brand riflescopes have lifetime...
not with a "tasco" there a bit of a cheepy scope, if it was a good make then it would be worth the cost of the repair, put it this way,,,the scope you fit to your rifle should cost 3 times more that the rifle did! a tasco scope on e-bay costs what? £150.00p to be honest theres a big "0" missing from that price?
Nov 09, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
The power is on but when i look though the scope it is blank
hit the reset, take the batteries out for 10 minutes so it resets, if that doesnt work you have to mess with the contrast.
Sep 13, 2009 | Vision Optics Atn Aries 330 Warrior Night...
Cross hairs canting to the left..how do i recenter the recticle?
From your short description, it sounds like the Horozontal (the ELEVATION) reticle is canted to the left. If that IS the case then do this;
Sand bag the rifle on what you know is a level and firm surface. The rifle MUST be level itself. You can use a small level to determine this.
Without moving the rifle, look through the scope and determine if indeed the horozontal or ELEVATION reticle is indeed canted. The reticle should be LEVEL in relation to the ground and the rifle itself.
If it still appears to be canted, loosen the set screws of the scope ring caps (Not the scope mounts) and while looking through the scope, gently rotate the barrel of the scope clock wise until the Horozontal reticle appears to be now level. Re-tighten the scope ring caps and look through the scope again to make sure the Reticle is still 'level'.
You must now make sure that your scope is still 'zero'd'.
IF the issue is something other than what I have assumed from your description, please send me a msg. with more detail and I will be able to resolve whatever issue you are having. Include the 'Brand and model', plus the power of it, and the brand/model/cal. of the rifle the scope is mounted on.
Good luck. :)
Apr 27, 2009 | Nikon Tactical Rifle Scope 4-16X 50...
Simmons scope that will not stay on target
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Feb 06, 2009 | Dual Electronics 6-24x50 AOE DUAL...
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Bushnell Sportsman 4x32 Riflescope (4x32 mm) Logo
1,069 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
