Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Extra door lock will not unlock at end of cycle
At the end of the washing cycle the door lock will not come unlocked. The only way I got it to unlock was to turn the power off and wait about 24 hours.
  • 958 Answers
Could be a defective door lock. these door locks have resistance within them and with the application of power, bi-metal moves and lock the doors.
test it again by using the unit and after 10 mins and the door won't un-lock , try to knock the door switch a little bit and see if it would unlock. if it does, then it is the door lock. it is getting sticky.
tnx 4 using fixya,
Posted on Oct 07, 2008
How do I stop my washing machine door alarm
go to instru.manual section troubleshooting and fix it. God bless you
if doesnot have it download from
However try this.
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima extra and the door won't open after the cycle has finished. The door lock light stays on. I have tried turning it off and running another cycle.
unplug unit for 1-2 minutes plug back in and then usually it will reset the computer.If this dont work you will have to take off top and pick the lock and replace door lock
Oct 27, 2010 | Washing Machines
Door will not unlock
You will have to remove the top cover, and release the door from the inside of the washer by forcing the door lock open manually
Please rate my solution.
Oct 30, 2009 | Hotpoint Ultima WD72 Front Load...
I have a Hotpoint ultima stream washing machine (WMA63) which the light says the cycle has ended but the water will not empty and we cannot open the door, any suggestions??
first to empty the machine--lower the drain hose at the back below the tub into a basin--once all the water is out--wait for about 3 mins and the door will unlock--then check your filter--probably pump prob
Oct 27, 2009 | Washing Machines
Door stays looked on washing machine
you will need to remove the top cover and get a screwdriver to move the door latch over. it's a job for an engineer really as you have an electrical problem anyway.
Jan 27, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint washing m/c WMA62 - door won't open
sounds like you have a blocked pump or discharge pipe
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Jun 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code F-01
Press "end of cycle button" for over 5 seconds, it will unlock. Note: the door should be opened only on hearing a click, or wait for 2 minutes after the wash completes.
I need a rating please, dont forget(!)
Dec 27, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima extra WD72
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Feb 28, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
532 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
