Question about Sport & Outdoor - Others
Gas Grill - flame always stays on high even though I've turned in on low
Have Kenmore gas grill - 10years old- -
Has 2 burners in grill - when turning burners to low -flame always stays high.
  • janetmusia Oct 08, 2008
    What is this - the only way I get a fix is if I pay for it...
    Thanks for nothing... I guess I'll just make a phone call..
  • janetmusia Oct 09, 2008
    That wasn't intented for you but for the service itself... I thought they had repair people that would actually try to help you. Sorry .
Hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Posted on Oct 08, 2008
  • infamouspk Oct 08, 2008
    sorry i tried to help no need to get pissy
  • infamouspk Oct 09, 2008
    no problem i hope u get your problem fixed
We have intermittent low gas flow to our Viking grill. We have replaced the burners and the regulator. It worked fine on Sunday but now today only the first burner lights (and it's low even though I...
Lynn, the problem lies with the gas regulator and the way you turn the tank ON. But it's readily solvable.
1. Turn the tank valve OFF & disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and set it on HIGH.
Does the flame height look correct? If so, light the remaining burners the exact same way.
Do all the flame heights look correct? If so, your solved the problem. Always remember to
open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. They run about $30.00 at any hardware store or home center that sells grills and accessories. Simply take you old one with you for comparison purposes.
Hope this helped you troubleshoot & solve the problem. Please let me know. Thanks.
Jul 06, 2011 | Viking VGBQ410-3RT Grill
My Coleman Seirra grill will not get to a temp greater than 300 degrees, even on high. Please advise. Thank you.
Does the flame height, when turned to HIGH on the burners, appear to be lower than normal? If so, it's one of two things:
1. You are low or about ready to run out of gas in the tank. Check gas level in tank.
2. The grill's regulated is partially locked up. Turn the tank valve OFF. Disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner farthest from the grill first and turn it to HIGH. Did the burner light and does the flame height look correct? If so. light the remaining burners the same way. Do ALL of the flame heights look correct? If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly.
If none of the above solved the problem and (hint) the burners are clean and not clogged. You need to replace the grill's Hose/Regulator Assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. They run about $30.00. Take your old one with you, just for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks and Happy Grilling!!
Jun 17, 2011 | Coleman Grilling
I have a Weber gas grill, and I just replaced the propane tank, yet when I ignite it on the Start/High setting, very little flame is produced. This is the first time in 5 years or so that I've...
Don't worry, you'll be grilling in no time, if you follow these instructions:
1. Turn the gas tank valve OFF.
2. Disconnect the grill's hose from the propane tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank's gas valve VERY, VERY SLOWLY (Slow Motion, slow).
Once the valve is fully open light one burner and turn it to HIGH. Has the flame height returned to normal? If so, light the remaining burner and turn it to HIGH. Do both flame heights look normal?
If so, you solve the problem! Remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 16, 2011 | Weber Baby Q Grill
Low flame at burner. I've put a new tank on my grill and now the flame stays very low on all burners. I've heard that there can be some pressure problems with a newly filled tank. Is there a quick...
Mike, there can be some pressure problems, but it's not the new tank. However, it does cause the problem and here's how you resolve it.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn the burn to HIGH.
Does the burner light and the flame height look correct? If so, light the remaining burners the same
way. Now, do all the burner flames look as the should? If co, you solved the problem. Always
remember to turn the tank valve ON very, very slowly>
If the above did not solve the problem, you will need to replace the grill's Hose/Regulator Assembly. You can pick one up at any home center or hardware store that sells gas grills and accessories. It will run you about $30.00 (+/-) .
Hope this helped you to solve the problem Please let me know & Happy Grilling!!
Jun 12, 2011 | Grilling
Cannot get high enough flame to cook - used to work beautifully and love the grill - all of a sudden not good flame
Either your burners need cleaning and/or the grill's regulator is locked up or the tank is low on gas.. This occurred when you either changed the tank or turned the tank valve ON. It happens very frequently. To solve the regulator problem, due the following:
Turn the gas tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow)). Once the valve is fully open, turn the burner ON. light it and turn the flame to the highest setting. Did the flame height return to normal? If so, you solved the problem. Remember to always turn the tank valve ON very, very slowly.
If the above didn't solve the problem and you've thoroughly cleaned the burner and the venturi valve, then you'll need to replace the grill hose/regulator assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. Take you old one with you for comparison purposes.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Apr 26, 2011 | Weber Q Grill
My gas grill when turned on will not stay lit sometimes 'When lityou can here air or something blowing and the flames are real low it doesn't even cook its so low I have it on high when we first got it, it...
Susan - Assuming that you have a Propane grill with a grill tank, that has plenty of gas in the tank. Do the following:
  • Turn the Propane tank valve OFF.
  • Disconnect the hose from the tank.
  • Wait 5 minutes and reconnect the hose to the tank valve.
  • Turn the Tank Valve ON, VERY, VERY SLOWLY (slow motion, slow).
  • Once the valve is fully open, light the burner farthest from tank, first.
  • Turn the burner flame to High. Has the flame height returned to normal? If so, light the remaining burner(s) the same way.
  • Have all the burner flames returned to normal? If so, you solved the problem.
  • Always remember, when turning the tank valve ON, do it VERY, VERY Slowly.
If the above did not solve your problem, you will need to replace the grill's hose/regulator assembly. You can find them at any home center or hardware store that sell grills and accessories. Be sure to take you old one with you for comparison purposes.
Hope this helped you solve your problem. Please be kind enough, not to forget to rate my response to you. Thanks and Happy Grilling!!
Apr 14, 2011 | Uniflame Grilling
Very low flame, like very little gas is getting thru, tank is ful
Okay, what you are dealing with is called "vapor-lock". The way these grills need to be turned off is, close the tank valve first and after the burners go out, then turn the burners off. The way you are doing it is trapping the gas and you are getting a weak flame. Fortunately this is an easy fix. First, light the grill by turning the gas valve open, then turn the burners on to light the grill...as soon as that is done, close the gas valve on the tank then turn the burners off. Repeat this procedure until you get a good flame. If this procedure hasn't fixed the problem after the third time, you need a new regulator and regulators are easy to find in any home improvement store like Lowe's or Home Depot.
Dec 15, 2009 | Weber Genesis Silver B Grill
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Gas grill lights but doesn't get very hot
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Mar 10, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Sport & Outdoor - Others Logo
347 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
