Question about EliteGroup ECS nForce 570 SLIT-A Socket 775 ATX MB w/SND LAN & RAID Motherboard
Find card reader
I have just built a unit for my daughter booted it last night everything worked great but I could not get it to find the card reader I installed? Its Ultra 7-in-1 twith a floppy drive , the card reader part has a four pin plug goes to the #3 or #4 usb header it just wont work. I pluged it to my computer in my office it has the same reader so the drivers are there and it worked? what do you sugest?? I uninstalled the driver and went to reinstall but it promps me that the reader cant be found ( EX- Pro) The floppy workes great it is IDE
  • 23 Answers
SOURCE: 741GX-M Sound not working, sound cards not being recognised
plz check wether u have installed xp service pack 2. if u have done this then go to the cmos settings and check wether the onboard audio is enabled or not. then install the correct driver for that device
Posted on Oct 21, 2007
hughv
  • 196 Answers
SOURCE: wont register the ide hdd
Do a google search for ecs p4vmm2
This should take you right to the download page where you can get the VIA 4 in 1 drivers. The url is too long to copy.
Double check  the master/slave jumpers on the hd.
Posted on Oct 26, 2007
  • 176 Answers
SOURCE: One problem, followed by another, followed by another
it seams that the motherboard has some power problems. Check on the motherboard for burned or blackened components, or for capacitors that are looking like they are going to blow (inflated on the top), u can do the same to the power supply.
If so change it !
Also maybe the power of the house has problems that the computers power supply cant handle (that can ruin the motherboard or other components )
U can also try to isolate the motherboard from the case (there might be a short between the motherboard and the power supply through the case metal ... )
Posted on Jan 20, 2008
  • 37 Answers
SOURCE: Internal memory card reader plug on the MB?
More than likely if you cant find it on the mother board it is on a Pci card.  Try looking at the different cards that are installed at a 90 angle from the motherboard.(they are plugged into the motherboard and when you look at the back of the computer you can see them as well)
If that doesnt work then post what kind of computer with what kind of mother board and i will figure out where it goes.
Hope this helps.
Posted on Dec 08, 2008
  • 66 Answers
SOURCE: cant' find driver for motherboard driver ecs p4m800-8237
Sound: http://eu.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1764&areaid=2&LanID=0
USB: http://eu.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2168&areaid=2&LanID=0
Posted on May 15, 2010
Hey my iphone is hangd up last night i did refresh and phone just hangd up and since last night home secreen just showing apple log and some times bilnk.i did switchd of and then switchd on but same.plz...
just try to remove the battery and leave it for at least an hour.
make sure terminal from the battery and phone is not corroded. check also that the battery is no faulty.
remove also memory card.
after that return the battery and turn it on. if unit boot successfully return the memory card.
if this hangs again after returning the memory card, then replace the memory card.
Feb 08, 2011 | Apple iPhone 3G
I insert my 4GB micro sd chip and click the F drive and it freezes the window until i take the card out. How do i get my chip to work?
Do not click the F: drive; right-click its icon and choose Tools, Repair/Checkdisk. See if that does the trick.
If it doesn't, you can try booting your PC with a Linux distribution such as UBCD and run tests from there. It is possible that the SDHC card is physically damaged, and UBCD's errors are more informative than a mere "window freezing".
Jun 13, 2010 | SanDisk 4GB microSD High Capacity Memory...
Hi there, my daughter turned the power off at the wall(whilst the system was running, importing music etc) and now the unit won't turn back on at all. i let it cool down with power detached, then reconnect...
From your description I would hazard a guess based on 32 years of experience that you have a power supply problem. It will need to be replaced. You may want to invest $35 in a UPS (uninterrupted Power Supply) system
Oct 05, 2009 | AOpen XC Cube EZ65 Barebone
Hello, my hp compaq nc6220 gives insert smart card into reader
Pl switch the machine off and put 2-3 pounds of pressure with your palm on the keyboard closer to the spacebar.. this will fix it..
it is caused by the weakening of the adhesive of the wires below the keyboard.
Long term option - get the keyboard opened by the an professional and cleaned properly..and fixed back neatly...
Apr 20, 2009 | HP Compaq nc6000 Notebook
Aspire 3690 built in card reader
the card reader shouldnt show up under my computer. but the cards should show up there when plugged in. you need to update your driver on the card reader. check in device manager to make sure everything is working properly.
Apr 16, 2009 | Acer Aspire 3690 Notebook
I am no tgetting sound from external speakers
Power down your machine
Unplug everything from it
Open it up
Remove your sound card and put it back in
Reverse the step and boot your machine
If it still doesn't work then you'll need to replace your sound card. You can find really good ones on Amazon for $25 or so.Remember to always turn off your speakers before you plug them into your computer. Since they are probably powered via AC adapter that surge of power could have shorted out your card. Good luck!!
Oct 01, 2008 | Microsoft Windows XP Home Edition
Kodak md853
hi! my sister-in-law gave me a MD853 camera last week from Canada. I used it over the weekend when we went on a trip and the pictures and videos i took were great. Last night, my daughter took a picture of me and when she took a picture of her brother, there was only white on the screen...like a moving white sheet with colored edges. I thought she destroyed it or something. I tried to use it but now the screen is all black...last night only the video worked but this morning everything is black. The other programs in the camera works so i suspect the problem must be in the lens. I'm in the Philippines and if I send it back to Canada for repairs it would just take a long time and it will be expensive to send it back. What can I do? I really love this camera... help!!!
Apr 14, 2008 | Kodak EasyShare C613 Digital Camera
Worked great until last night....
hi put some exhaust fans in the case see if this will help youi had this happen to me a few times add fans and als wellremember you still have your chip set on your mother board they do not have fans and need to be cooled too
Nov 03, 2007 | ASUS A8N32-SLI Deluxe Motherboard
POWER ON, WILL NOT BOOT
Sounds like you definitely have something that is intermittently not making proper contact. I'd suggest checking all of the cable connectors first. Disconnect each one and reseat it. If that doesn't do the trick, you may have a broken land pattern on the motherboard. That usually means a motherboard replacement.
\R-
Oct 29, 2007 | Compaq Presario X1000 Notebook
EliteGroup ECS nForce 570 SLIT-A Socket 775 ATX MB w/SND LAN & RAID Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
