Getting error code ox45A and says fatal error with power saver. How can I restore this?
  • Anonymous Apr 28, 2009
    what is error 0x45A
2 Suggested Answers
SOURCE: toshiba power saver fatal error
Okay I don't know if this will work for you, but bear with me, cause this is what I did and it fixed my fatal error.
First Download System Mechanic (theres a 30 day free trial you can use for the time being)
After it's done downloading and you've installed it. Do a deep Analysis of your system, and some errors will come up. Have the program fix them for you (if there are some you don't want to fix just hide them, and if your unsure about them, just go ahead and fix them). After this restart your computer whether or not the system mechanic asks. If after a restart it still gives you an error, download the latest version of the toshiba power saver which is currently 7.08.05. I have a toshiba U205 so there wasn't a specific one for mine, so I downloaded the Toshiba Satellite R20-ST4113 Power Saver Utility 7.08.05 Windows X.
Which still worked for my system since it's an XP. If yours is a vista, I recommending finding one for vista.
After this again restart your computer to see if it helped. I hope it helped with your problem. If not i'm sorry I couldn't give anymore advice.
Posted on Sep 16, 2008
E pa au u5 5e
Good Morning Friend,
I understand that you are receiving multiple error codes on your Frigidaire Affinity washer, model# FAHE4044MW. I see that the error codes showing are "E", "PA", "AU", "U5", and "5E". I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
WP
May 15, 2014 | Frigidaire Affinity FAHE4044MW 27"...
I have a KonicaMinolta Magicolor 3730DN. It fails with Fatal error code 0F55H.
Toner level sensor for the black toner is bad or the black toner is not getting into section where that sensor is. ensure your black toner cartridge is OK
Oct 05, 2012 | Minolta magicolor 2200 DeskLaser Printer
Toshiba Power Saver. Fatal error Code 0x7E
uninstall Power Saver while in Safe Mode, reboot into Safe Mode again, and reinstalled Power Saver
Jul 05, 2012 | Toshiba Computers & Internet
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
Toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
Aug 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba power saver fatal error 0xb7
Jul 30, 2008 | Toshiba Computers & Internet
Toshiba power saver keeps on saying that it has encountered a fatal error 0x2 even after i have reinstalled the common modules and power saver HELP I have an M500 portege
try the original laptop recovery cd for the power saver utility of ur specific model...this works best..
many people downloading TPS from the website have had no luck it seems
Apr 14, 2008 | Toshiba Computers & Internet
Toshiba Power Saver
It sounds like the built in powersaver utility is crashing. Assuming you can log into the OS after the error, go to Control Panel - Power Options and change to some other (or none at all) setting. And/or uninstall the application completely.
If you can not even get into windows you could try changing the power settings within to bios to disable power saving at all, and that might allow you to boot properly and then turn off/uninstall as described above.
Jan 16, 2008 | Computers & Internet
Computers & Internet Logo
519 people viewed this question
David Payne
David Payne
