Dab radio logik logkc50d
I can\'t set the clock or the alarm.
5 Suggested Answers
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Posted on Jan 25, 2008
SOURCE: operating instructions for timex t311t radio/alarm clock
Regarding how to set the time on a T311T Clock:
1. Push down the Time button and hold until number start flashing.
Push the right arrow until the time advances to the time desired.
2 To set the date, push the date button and hold until date starts flashing. Push the right arrow until the date advances to desired date
Posted on Jul 19, 2008
welcomejee
  • 10594 Answers
SOURCE: I have lost instructions
Please download required Instruction Manual from HERE.
Posted on Feb 03, 2009
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
Posted on Mar 04, 2009
  • 5 Answers
SOURCE: do not know how to turn off alarm setting for clock radio
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Posted on Feb 21, 2010
Hi.i've lost manual for bush dab alarm clock,cr231 dab can anyone help?
Hi go to the company website and look for downloads click on this and look for your model you should be able to download a copy of the manual from there
Feb 02, 2015 | Audio Players & Recorders
The time does not automatically set on my sony alarm clock XDRC706DBP
Afraid I have the same problem and I have to manually set.
good luck !
Jul 07, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
Xdr-c706dbp time settings changes all the time
Yes - I'm in Sydney and the clock intermittently changes time to -11 hours which is GMT - it has always had this problem and I have never found a fix. HELP
Jan 08, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
I have a logik logmi4007 (radio alarm clock with ipod docking station) and can't reset the programmed radio station - no instructions - any ideas
I recommend that you will post your question under the correct category (personal radios).
You can also contact the store that you got it from to get the instructions.
Sep 17, 2012 | South Shore Logik Collection Contemporary...
I bought a bush dab radio ne-3125, was advertised as a clock/radio,is this right or is it just a radio ?
I had the same problem - alarm going off at midnight. Hold down the Menu and Select buttons at the same time to reset the radio. This removes the alarm. It will rescan and find all digital stations again but you will lose any presets.
Sep 07, 2012 | Audio Players & Recorders
I have lost the operating manual for a technika DAB 109 Radio
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Mar 07, 2010 | Audio Players & Recorders
I have a proline DAB 100 alarm clock radio, I went
I am finding difficulty to set the clock on Proline dab 100 fm
Jan 03, 2010 | Audio Players & Recorders
Instructions for setting alarm on Alba PD2 DAB/FM radio Thanks.
Hello All,
I have an Alba PD2 DAB radio and have set the alarm to come on with the radio. The problem is it comes on at a very loud level. Is there a way to set it at a lower level ??
Dab Des
Setting the clock?
select the slide on the top to set clock, then use minutes and hour buttons to adjust accordingly, slide to alarm and repeat, press set button if no slide, also, have alarm set to buzzer/radio accordingly, and alarm 1/alarm 2 accordingly if applicable.
Oct 20, 2008 | Audio Players & Recorders
How to work / setBuch radio alarmclock
I just found my manual for the Sharper Image SI785 CD/Radio Alarm Clock with Sound Soother. Had misplaced it for quite a while. Am not saavy enough to know how to post it online, but if anyone needs one, just email back your address and I'll be happy to send it. I remember how frustrating it has been trying to program/reprogram one without it. Looking forward now to knowing how to use this thing :)
Jun 07, 2008 | Audio Players & Recorders
250 people viewed this question
 Grubhead
Grubhead
