Question about IBM Infoprint 1352 Laser Printer
How to enter maintenance menu on 1352
How do I enter into the maintenace menu on the Infoprint 1352. I need to change fuser temp, reset maintenace meassage, etc.
Thanks in advance!
  • 32 Answers
Turn off the printer. Hold Go and Return and restart the printer. hold until you see performing self tests. That is Diagnostics mode.
Posted on Jul 24, 2009
Need reset fuser instructions on ibm infoprint 1352
Refer to the service video at the following location:
http://www.fastprinters.com/TechSupport_repair_parts.asp#T640VIDEO
IIt shows you how to perform the maintenance and reset the maintenance count.
Mar 18, 2014 | IBM Infoprint 1352 Laser Printer
Reset maint counter
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
2. Press Return to go to the previous menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the Diagnostic menu.
To reset the Maintenance Page Count to zero:
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
Error 80-maintenance
The operator panel displays this message at each
300K page count interval. It is necessary to replace
the fuser assembly, transfer roller, charge roll, and pick
rolls at this interval to maintain the print quality and
reliability of the printer. The parts are available as a
maintenance kit.
Description Part number
Infoprint 1332/1352 Infoprint 1372
115 V Maintenance kit 56P1409 56P1855
220 V Maintenance kit 56P1412 56P1856
100 V Maintenance kit 56P1413 56P1857
I have new Maintenance Kits in stock at this time. You have the option of doing the kit on exchange or outright. Your Part # should be 56p1409 if you are in the US.
Please give me a call for pricing of if you have any other questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
AOL IM: RORYMRP
rcardenas@mrp.to
Jul 07, 2009 | IBM Infoprint 1352 Laser Printer
Keep getting an error message "202 Paper Jam Open Rear Door", cannot clear the message. We ordered a maintenace kit maybe 3 months ago.
If you can't see any paper stuck inside the printer when you open the rear door or when you remove the toner cartridge, the rear paper flag is either stuck or broken.
The flag is a small piece of plastic which sits at the rear of the fuser and as the paper exits the fuser it pushes the flag down. The easiest way to see this is to remove the rear door then the rear cover (two screws).
If it's broken you'll require a replacement fuser (i don't think you can get the part separtely), but if you have recently installed a maintenance kit, i would contact the supplier and ask for a replacement.
Apr 20, 2009 | IBM Infoprint 1352 Laser Printer
Info Print 1352 one half faded other half normal print.
You require a replacement transfer roller, if you remove the toner cartridge and look in the printer, you will see a roller which sits underneath the toner cartridge, this is what you need to replace
Jan 13, 2009 | IBM Infoprint 1352 Laser Printer
Infoprint 1532 Faded txt on left half of page and normal on right
The problem is the transfer roller. If you remove the toner cartridge and look at the roller that is under it. It should be seated down. The gears should be on the left side. Try to remove it and replace it the correct way.
IBM 1352 Infoprint
It means it's due for a service, normally the consumables ie fuser, pick up rollers, charge and transfer rollers are coming to the end of their life.
Aug 18, 2008 | IBM Infoprint 1352 Laser Printer
Maintenance shedule error
Power off the printer and hold down the two top right buttons and power the printer back up. You will be taken to a menu that you will be able to scroll through. Look for the "Maint Count Reset" option and press the "enter or go" button and reset the count.
Aug 17, 2007 | IBM Infoprint 1332 Laser Printer
IBM Infoprint 1352 Laser Printer Logo
461 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
