Flashing screen(monitor) my computer screen is flashing,it does not show at all.so i want to know what could be the problem? i thought i did misconnection but i tried to check on that, it was well connected.
  • 285 Answers
Well, there's a load of things that could cause that problem. Your mainboard could be broken, or your videocard, or maybe some of the cables to your monitor doesn't work as it should, or one of the pins on a conector are bent, or the monitor is broken, etcetera, etcetera. As for the solution, when exactly does your screen start flashing? Immediately when you start up, or only when your OS starts. If that's the case, you should try starting in safe mode. (usually bound to F8). If not, you should try connecting the monitor to another PC, and see wether it works with that one. That at least eliminates some of the possibilities.
Hope this helps!
Yannick
Posted on Oct 17, 2008
White screen showing on monitor
Sounds like you have a bad monitor.
Try unplugging the monitor for several minutes and re-connect.
Also, you may want to re-seat your video card on PC.
If you have another monitor to check your video with, it would help.
Hope this helps.
Mar 22, 2014 | eMachines 15 inch Monitor
All my characters are showing shadows is this a problem with the monitor or with the computer?
Hook a spare monitor to the computer, if okay! the problem is in the HP monitor. Now if symptom is the same on both screens, the Video Graphics Card is defective. Last thought replace the video cord from the computer to the monitor just to be sure.
Apr 03, 2012 | HP w19e 19" Monitor
The monitor wont work
plug back to vga and setup multy screan c
Jun 25, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
L1932TQ monitor flashes on, then blacks out
I would try connecting it to another computer or Laptop if you can to see if the problem is the same. You might also try disconnecting it from you computer and turning it on, it should “banner”(show a logo and or a no signal message). If it behaves the same way just a quick flash…. Sounds like its toast.
Jun 20, 2009 | LG L1932TQ LCD Monitor
Blue hue on screen
Try a different known working monitor on the vga port of your laptop. If the replacement monitor works then you definitely know its a problem with your original monitor. If the replacement monitor shows the same blue hue then you know the vga port is bad on the laptop which would mean replacing the motherboard since its connected to the laptop.
May 30, 2009 | Acer AL2016W 20" LCD Monitor
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Screen Display at rest
Hi, your monitor is working just fine, that is the test mode, showing you the three colors. This is the colors needed for the monitor to show all the other colors, with this the monitors have a problem..
Jul 31, 2007 | BenQ FP731 17" LCD Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
