Question about ASUS P5B-E Motherboard
Upon booting hard drives not recognized
Hi--
Have an Asus P5B-E motherboard, worked fine for the last year or so since I built it, but now when booting it doesn't recognize the hard drives.
-It will allow me to go into BIOS and Setup
-Hooked up hard drives to another pc and they were recognized/worked fine
-Did nothing strange or funky to prompt this
-Cables secure
IT guy at work thinks the motherboard got fried; I'm thinking it maybe has something to do with SATA controller, if there is such a thing?
ANYWAYS...any suggestions out there as to what might be causing/what I can do to fix this?
Thanks!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
You mite try to re set the board and I would start with just one HD with the OS shut down pull power plug push the power on switch to let out res power then locate the the bat on the board and remove it you will see a pin select set near the bat pull the connector and change the posision to the other pin (touch the two not together at first) then replace it the way you found it wait a few moments then try to boot again
Posted on Oct 07, 2008
Hi, my P5B-VM DO motherboard fails to boot. I'am
Usually the indication of a failed hard drive, in as much as the operating system is either missing or corrupt.
Apr 07, 2012 | ASUS Computers & Internet
My Asus P5B-E wont start. I have power led blinking after i turn on power on and computer is just blinking and making sound like he is starting but can't. First time this hapens i took 15 minutes and...
this can be caused by a number of reasons
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
hope this helps you
Aug 04, 2011 | ASUS P5B-E Motherboard
Asus P5B-E motherboard won't resume from hibernation
You may want to verify your bios version and perhaps download/install an update from this page. It's worth a try to see if it clears up the problem.
Mar 16, 2009 | ASUS P5B-E Motherboard
Want to run both Raid 5 (4 drives) and a single SATA boot drive
Download the latest beta BIOS 1238. I had the same problem when adding a Samsung 1TB HDD to my RAID config. Updating to BIOS v1238 solved the Intel RAID Matrix "hanging" instantly.
You can't download it through the official Asus support page yet, but there's a topic in the Asus support forum with a link. You could also call Asus support and request the file, or just download it here: http://rapidshare.com/files/186891601/P5B-Deluxe_1238.rar :)
Feb 07, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
Asus p5b-mx motherboard not showing display but every thing is on
Hi camlamm, check out Asus CPU supported list link;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5B-MX&os=17
See if your CPU is in the list.
Bios not booting? If you are receiving any display on your monitor the trouble is not the graphics card. Suggest you clear the cmos jumper. See page 1-26 instructions your manual. This Asus board is warranted for three years. If nothing gives you access to the bios, suggest you call Asus tech, M-F, 8:00AM to 5:00PM EST at: 1-812-282-2787.
Good luck camlamm!
Thank you for using fixya.
Mike
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
2 Sata HDD not working at a time
In the bios be sure that all the parameters for the SATA drives/devices are AUTO
Dec 11, 2008 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
On barebone asus p5b-mx 1st try won't boot display but led is on
Hi There,
Disconnect the hard drive ribbon cable from the mother board and try again. carry on disconnecting each component at atime and trying again. Leave the video attached. this is going to be a process of elimination. sooner of later you will find out where the problem is.
My personal feeling is that the hard drive is connected incorrectly.
Let me know if you want further help.
Regards,
Philip
Dec 09, 2008 | ASUS P5B-VM DO Motherboard
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Slow boot
You could have a USB device connected and switched on and when you boot its trying to find it and boot from it
You could set BIOS to boot from hard drive to see if it fixes it
Sep 12, 2008 | ASUS P5B-E Motherboard
ASUS P5B-E Motherboard Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
