Question about Lexmark X1150 All-In-One InkJet Printer
Leaking Ink Jet Cartridge.Clogged Up My X1150 Printer
I Sent A Letter To Customer Services On September23rd 2008.It Was About A Lexmark Ink Jrt Cartridge Leaking And Clogging Up My X1150 Printer.To Date I Have Not Heard A Thing If I Do Not Recieve A Reply By E Mail To linchas@supanet.com Or Phone 01553 811716.I Will Be Taking It Up With Consumer Complaints >Ref No EE418316 Charles Craske
No Solution Found.Get Lexmark Customer Services To E Mail Me Or I Take It Back To Trading Standards. C>Craske
Posted on Oct 08, 2008
Puchased ink is unsupported
FIXYA can not assist you either . MOST printers now will not work with non OEm cartridges .
Mar 10, 2017 | Lexmark E260dn Laser Printer
When I try to print from my Lexmark X1150 it says that the wrong ink cartridges are installed but I am using Lexmark 27 and Lexmark 17 - I thought these were the correct ones - can you advise...
The 17 and 27 cartridges are compatible with your Lexmark X1150 printer. Try to manually wipe the cartridge nozzles with a soft moistened cloth. This will help clean the nozzles from dirts and clogs. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert one cartridge first. Close the cover. If no error, open the cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark X1150 All-In-One InkJet Printer
What are the steps to cleaning the print heads on the X1150 printer? New at this. Mike
On your computer, open the Lexmark Solution Center (go to Start, Programs, Lexmark 1100 Series, Lexmark Solution Center) > From the Maintenance tab, click Clean to fix horizontal streaks > Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles.
Source: How to Resolve a Blurry Print Issue Without Replacing the Cartridge
May 07, 2011 | Lexmark X1150 All-In-One InkJet Printer
Fails to print even though it has new cartigages of ink. what is the problem?
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 17, 2010 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Cannot connect with my lexmark printer X1150. UBS connection
right..
remove software through control panel printers
then go here for fresh set of drivers(look for lexmark icon)
re install with printer not connected to computer
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Black ink
Did you remove the tape from the cartridge when you installed it?
Has it ever printed black from this cartridge before?
You may need to wipe the cartridge with a moist paper towel at the place where the ink comes out. If there is dried up ink the nozzles could be clogged. Try running the Lexmark Solutions Center from the Windows Start menu (Start -> Programs -> Lexmark 1100 Series) and make sure the black ink level is good. You can also select "Clean Nozzles" in there and that may help.
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
97 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
