Question about HP Photosmart C7280 Printer
Print Envelopes on HP Photosmart 7280
I can't get my printer to print envelopes - size 9 5/8" x 5 7/8" (24.4 cm x 14.9 cm). How do I do this?
  • 2 more comments
  • jpatte4923 Nov 16, 2008
    Even if I change the settings in page set up the same message pops up with "paper mismatch". Help me please.
  • Anonymous Dec 03, 2008
    I did what you said but keep getting paper size or type is incorrect, I have a Mac
  • aiutomi Dec 10, 2008
    Sowftware only allows envelope #10 - 210x297 mm. I wanto to print C6 - 162x229 mm. I find the software inadequate.
  • jcg3t Jan 15, 2009
    I get the same message when trying to print a 5.25" x 7.25" envelope. I do not find anywhere to change the name of a page size. Do I change name under document or envelop?
I need to print the address on a 5.5 X 8.75 envelope. Is there a way that I can turn the envelope 90 deg. and have the printer address it correctly?
Posted on Dec 19, 2008
  • 171 Answers
This is a paper size problem with the software, go to page setup and under "Paper Size" choose "User Defined" or "Custom" and fill in all of the dimensional information about the envelope and save with a name you will recognize. Now, when you print make sure you have selected the envelope from the paper list and you should be good to go. If you need further assistance, click "Ask Me" and I will answer your request as soon as I can.
Posted on Oct 07, 2008
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
Need help printing customized size envelopes
you need to set the preferences in the 'Page Setup" to print envelopes
try this
good luck
Apr 29, 2010 | HP Photosmart C4180 All-In-One InkJet...
How can I print envelopes on my HP C5180. I've had it over 2 years and have never been able to get it to print any size envelopes. I always get a 'paper mismatch' message. HP tech support has never...
I tried all of the suggestions on here and nothing worked. My envelopes are 5x7.3. So, I finally just put in 5x7 and lo and behold, even though there truly was a paper mismatch this time since that was NOT the size of the envelopes, they printed. I did have to move the text boxes some to make them print correctly. So, I guess the solution for my printer is to actually mismatch the size of the paper/envelope so that you will NOT get the "paper mismatch" error message. Will it work on other size envelopes? I have no clue. This is the first time I've ever been able to print an envelope at all with this printer that I've had 2 or 3 years.
Dec 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart Premium c309a series will not print envelopes. I keep getting an error message that says paper mismatch. It doesn't matter what size envelope I put in, it always gives me an error message....
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Sep 21, 2009 | HP Photosmart Premium C309A All-In-One...
Envelopes keep getting stuck
Open Ms word >> click on tools >>click on letter and mailing >> click on envelop and labels >>click on feed >> click on envelop option >> can change the size from the drop down option.
This will resolve your issue.
Aug 17, 2009 | HP Photosmart 7850 InkJet Printer
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Jun 14, 2009 | HP Photosmart D7460 Printer
I cannot print C5 envelopes on HP C7280
In page setup manage custom paper sizes. Enter the size of the envelope and save it. In print dialogue box you can find the C5 envelop. Paper size: defined by driver. This should work
May 07, 2009 | Office Equipment & Supplies
Need to print a half-fold card envelope with HP Photosmart C4480
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7280 Printer Logo
2,241 people viewed this question
Ben Johnson
