Question about Roper MHE14XKB Microwave Oven
No heat in microwave
No heat , all lights work, fan also works clock ect. I have changed the
2 fuses 250 vac 10 amp ,still no heat My microwave doesn't heat. All else works (clock, lights, fan, etc.)
  • 2 more comments
  • tvcallaway Nov 21, 2008
    no heat in microwave problem
  • Anonymous Jan 11, 2009
    I have the same problem but the turntable doesn't work and it doesn't heat. Everything else works.
  • dna42754 Mar 19, 2009
    same problem here.everything works but the turntable and there is no heating.help?
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises? Is it louder or quieter than usual?
    Is the model number MHE14XKB as per the question's category?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • Roper Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
GE Model # JVM7195SFSS microwave.
Check the internal ceramic fuse on the circuit board. Sometimes one section will work while another won't. I'm not sure if this model has a rear mounted thermal fuse, but the models with the inline thermal fuse will cause a similar issue.
Jul 04, 2014 | GE XL1800 1100 Watts Microwave Oven
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
Where is the fuse in under-counter miccrowave?
remove the vent grill at the top, may have to slide to left after screws are removed. then you will see a screw holding the control panel, remove. then slide the panel up slightly and the panel should come off. behind the panel you fine a 20 amp 250 vac glass type fuse. remove and replace. if your MW works cool,,,,, if it does not you may need to call for service.
Jan 23, 2012 | Amana Microwave Ovens
No power but outlet is functioning properly
There is a ceramic fuse inside the oven. Remove the case and follow the cord from the back of the oven to the fuse. Replace with on of the same amp size.
Jun 19, 2010 | Goldstar MV-1501 Microwave Oven
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
I have a sanyo microwave fitted with a 10a/250w fuse had blown during cooking,didnt have another ceramic fuse but replaced it with a glass 10 amp fuse , all electrics came on set the clock ok ,but when put...
10 amp 250 watt??? no mate! thats volts,,but so what
you have a problem with the microwave if its popping fuses it has a big problem they just dont pull that much,, if it popped another 10 amp 250 volt fuse its in need of looking at as there is a very big short inside of it,, how old is it??? and now there so cheap to buy would it be worth just getting a new one?,,,oh,,by the way,,,dont go poking about inside of it,, there is a very big capasitor in there and its a killer even if its un-pluged for weeks! have you ever seen a police stun gun working??? well this cap is no stun gun it makes them look like toys but they do bite realy hard even to the point of killing you out right! so please play it safe, just go and buy yourself a nice new microwave and live to show it off to your palls
Mar 03, 2010 | Microwave Ovens
Microwave does not heat but everything else appears to work the clock ect. model number JVM1653Wd004
Remove the outer case and look for a blown fuse. If found, replace the high voltage diode and the stirrer (a fan-like device that commonly shorts it's plastic bearing), which sits inside the sheet metal waveguide just over (or beside) the area where the microwave energy enters the cooking cavity. Test with a cup of cold water. Never operate the oven 'empty' as it will arc without a 'load'.
Oct 20, 2009 | Microwave Ovens
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Roper MHE14XKB Microwave Oven Logo
290 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
bigdawg7299
Gere knutson
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
