Question about Canon Pixma MP500 All-In-One InkJet Printer
Mini sd card stuck
Accidentally inserted the mini sd card without the adapter and it is now very stuck. Canon say they charge £95 call out fee. Easier to buy a new printer but I like this one so if you can suggest how to get the mini sd card out that would be good.
  • 76 Answers
I would say get a pair of twezzers and try and pull it out, if not turn it on its front and hang it off the end of a table and try and pick it out,
this has happen a few times but it is not Canon fault as its does not take those cards.
i would try and get it your self.
only thing you can do!
Posted on Oct 24, 2008
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
Mar 31, 2011 | Computers & Internet
Cannot download pictures from phone to computer
The easiest way to transfer pictures from a cell phone to a computer without incurring addtional charges is to transfer the pictures to a mini SD card and then insert the SD card into your PC. If you will tell me what kidn of phone you have, I can try to find the directions for where to install the mini SD card and how to transfer the pictures. At that point, you can also set the camera to automatically save the pictures to the SD card to save yourselves steps next time. : )
Mar 03, 2011 | Cameras
How do i unprotect my memory card from a canon 450d?
Thanks for using Fixya.
Every SD card should have a write protect switch located on the right edge, about 5mm from the top of the card. In order to unlock the card, slide the switch upwards.
Note that with Mini SD and Micro SD (Transflash) these switches are not present. The card is always unlocked. A switch may however be present on an SD card adapter.
Because of the position of the switch they can often be switched accidentally on inserting or removing the card.
Rating the solution is highly appreciated.
Apr 14, 2010 | Canon EOS 450D Digital Camera
SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Aug 13, 2009 | HP Compaq nc6230 Notebook
Problem with the mini SD Card
Thats weird! This is the right size of SD card for your camcorder. http://www.tristatecamera.com/lookat.php?sku=1GBSD80MINI&stsid=CANHG10 Did you try one of the same size?If yes then Did you try an adapter like this one? http://www.nextag.co.uk/INTEGRAL-Micro-SD-Card-1508586241/uk/prices-html?nxtg=16420a280d0a-59E6FEB3CB48EF1E You should get an adapter of appropriate size and place the micro SD card in the adapter and then insert the adapter into the camcorder.
Jun 11, 2009 | Canon HG10 HD AVCHD HD Camcorder
I hav'nt got a disc to download onto my computer so i cant get any photo's from my phone to my computer
Transfer your photos on your phone to the mini sd card in your phone. After they are on your card, take the card and insert it in a mini sd reader or a sd/mini sd adapter and plug that into your computer... works great,
Jun 07, 2009 | LG KC910 Renoir Cell Phone
Sandisk Adapter Problem in a HP Laptop
If you install SP3 it may work as SP3 updates the index parameters for file size limitations within such an old OS.
Oct 11, 2017 | Electronics - Others
SD card reader
1) There is SD card reader on pavilion dv 1000, so you need adapter in which you insert mini SD card to make it SD
2) If you have that adapter, check adapter. Maybe it's broken.
3) If your card is biger, like 2GB or higher you may try updatenig drivers (I read on one web page: " There was a software update for support of reading and using higher memory SD cards, for my pavilion ZV5000, on the HP Software update website." )
May 31, 2008 | HP Pavilion dv1000 Notebook
SD Card reading problem
Problem is your SD adapter for your mini SD card!!! Try with other and you will see that will work.
good luck
Jan 30, 2008 | Computers & Internet
Canon Pixma MP500 All-In-One InkJet Printer Logo
150 people viewed this question
old marine
old marine
