Question about Viking Refrigerators
Eaton viking fridge model RF1717
Every week I have to defrost freezer. It seems that if the frost builds up in freezer, the fridge gets warmer. Room temperature warmer. As soon as I defrost the freezer for the day, the fridge is really cold again. It is an older fridge so I am not into spending alot of money to fix it, but hey maybe I will get lucky and it will be a simple fix.
Thanks for anyones help in advance
  • conniebabine Oct 07, 2008
    You say to check out other problems as detailed below? Where exactly should I find them?
    Genius:
  • 1,239 Answers
Hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.
Posted on Oct 07, 2008
Hi, I have an Electrolux French door fridge. the freezer keeps developing ice over the back panel and then the freezer shuts down. I have turned the whole unit off for 36 hrs to defrost and then turn it...
You have a defrost issue causing frost/ice accumulation on the back panel of the freezer and stopping air flow across the low side.
When this happens the air flow is stopped to the fresh food and its gets warmer by the day until it is finally defrosted. What is your model #???
Oct 17, 2013 | Electrolux Refrigerators
Viking refrigerator freezer bottom mount. frost builds up on back wall behind cover panel in freezer. once we self defrost, runs great for 3 weeks and again we defrost with a hair dryer.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 09, 2011 | Refrigerators
Frost build up on back panel. 3 weeks ago used hair dryer to melt ice behind panel that was on the coils. Now we are getting frost on the coils and the top of the freezer door. Refrigerator section is now...
The defrost cycle on this fridge is not working. Ice is building up, restricting the air flow to the food section causing the area to warm up, the defrost components need to be tested to find the fault
Apr 01, 2011 | Whirlpool Refrigerators
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
Our top mount Kenmore fridge (Model # 253.77872509) is frosting up in the freezer section. Have turned off & defrosted the freezer on several occasions - it works for a few weeks but then begins...
Normally when frost build up occurs it's because warmer outside air is getting into the freezer and the moisture from that warm air cools and condensates then freezes into frost or ice. You either have a bad seal like the other listing states try leveling the front a little higher than the back. Or you may have an issue with the defrost heater, thermostat or timer. Do you have a light that comes on from time to time? If so you have an auto defrost unit. If there is no light you may not have a frost free freezer which means you will have to remove the frost manually.
Please check the bellow links for your knowledge:-
http://www.wikihow.com/Stop-Your-Fridge-from-Ice-Build-up
http://www.ehow.com/how_4781069_prevent-frost-build-up-freezer.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Kenmore Refrigerators
Frost forms in freezer, blocking vents so temp in both freezer and fridge is warmer than normal
You have an issue with the defrost system, either the timer, thermostat or heating element. Probably the defrost timer refer to the manual to find it. If you don't have the manual check the makers web site for a parts breakdown. You should be able to put it into defrost manually by turning the knob and see if that helps. You may need to do this sevral times as it only stays in defrost for a little over twnety minutes and run cycle for 6,8 or ten hours. If the ice build up is heavy then twenty minutes may not do the trick thus the need for repated defrost cycles. If it does the trick replace the timer. If not check the thermostat and heater element.
May 18, 2009 | Kenmore 22.4 cu. ft. Bottom Freezer...
Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Fridge does not get cold
If your getting frost build up in the freezer..u said u tried defrosting... is frost building up it freezer?
IF so you have a defrost problem...bad  heaters, defrost themostat or defrost timmer, if ya need more help post more info
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 23, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Refrigerators Logo
467 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
