Question about Dell 3100cn Laser Printer
DELL 3100 CN
Restart Printer
  • 1 more comment
  • Anonymous Oct 08, 2008
    When I replaced the drum I got the 004-321 message.
  • tfc2008 May 11, 2010
    Can you be more specific about where the sensor is located?
    can you more specific on what/where the ibt sensor is located?
    An expert whose answer gotĀ voted for 100 times.
  • 188 Answers
This error, 004-321, is that the MCU can not receive the output signal from the IBT ( intermediate belt transfer assy) at the specified timing.
There are several possible causes for this.
1) the IBT unit is defective. even if it is new, in rare instinses, they can be out of the box defects.
try reinstalling the old unit and determine if the same error exists. If that error goes away, the new unit is defective. request an RMA from the supplier and replace with a known good one.
2) the IBT sensor is defective ( or dirty... toner dust obstructing sensor ). This sensor is located at the left hand side of the metal cross bar underneath the IBT when removed. Try blowing out the sensor with a can of compressed air. Be careful not to spray this at the toner cartridges directly as this will just blow more toner up into the air, and the fine toner dust should not be inhaled. I would suggest putting a paper towel between the sensor and the cartridges before using the compressed air for that reason.
There are other possible causes for this error, all of which are far more expensive to repair and even less likely to be the cause, as your printers were working before changing the ibt's out.
Good luck :)
( if you found this solution helpful in resolving your issue, please remember to rate the solution as "fixya"..
Posted on Oct 10, 2008
1/2" white line appearing down right side of page
Try replacing the toner cartridge. This seems to be a problem with the photo-sensitive drum, which is located in the cartridge.
Jan 05, 2010 | Dell 3100cn Laser Printer
Hello My printer(3100 cn dell) every time I
This means that loose toner powder has gotten in the way of the lazer "eye". If you open up the front door, you will see a blue tab toward the right, pull that toward you, then look on the right side of the printer, you will see that a door has opened. Pull that blue stick out as far as you can and you will see some toner powder on that, clear it off, and make sure the little pad is clean. After you have cleared the powder off, slide it back in and out a few times, this will clean the eye. Run another document through, if the line is still there, just clean another time. Should go away. I have this problem alot.
Aug 13, 2009 | Dell 3100cn Laser Printer
Dell 3100 CN Prints a stip on black all the way
There is a known issue for these printers to "streak." If under warranty, call Dell. If not, there is a fix
for the defective drum unit design but requires a little technical expertise.
The procedure is explained here:
Jul 08, 2009 | Dell 3100cn Laser Printer
Cannon IR 3100 CN Itermediate Transfer Belt error code E00070-000
The E00070-000 is not a ITB problem, but a full wastetoner. Open the front cover find the white bottle in the middle, remove the black screw, remove the cover over the top of the bottle and empty the bottle. Be sure to clean the top of the bottle so the sensor can see that the bottle is empty. Restart the copier.
Jun 04, 2009 | Canon iRC3100 Printer
The new magenta cartridge you put in is bad. If you put the old one back in then you get the low toner message. Take the new cartridge back and get another new one.  I found the answer on the dell troubleshoot website
Feb 03, 2009 | Dell 5100cn Laser Printer
LDell 3100cn awer printer won't recognize new toner
Have you removed the plastic protection strip from the bottom of the toner?
Nov 14, 2008 | Dell 3100cn Laser Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
Linux printing with Dell 3100CN
OP provides the solution! (BTW, I'm able to print to this printer from MacOS too.)
May 01, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
776 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
