Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold side by side
I hear what seems to be a fan, the lights work but not freezing and not getting cold. It is approx. 4 years old.
  • 958 Answers
If the fans are working, can you detect if the compressor is also working/running?
the compressor is located at the back side , lower portion. remove the back cover and observe the compressor if it is running.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
Fridge and freezer not staying cold - Got home last night and my whirlpool (frost free) fridge/freezer was switched on (power running to it - light etc working) but was not chilling properly. Everything in...
This can happen if the fan motor in the freezer compartment is bad. Causes the freezer section to freeze up and you will not get air circulating, so no cooling. Check the fanmotor
Nov 06, 2009 | Cars & Trucks
The lights are on but it is not cooling or freezing
The overload/relay is shorted . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . Pt # 8201786 . Remove the back refrig panel to access the compressor . This part is easily replaceable . Instruction come with the part(s) . A little plastic "clip" needs to be released , when removing the plug from the part , by using a small screwdriver .
Sep 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Hello, I have a Whirlpool refrigerator that is just over a year old (Model #ER8YHMXSB00). The freezer seems to be working fine but the refrigerator will not cool below approx. 50 deg F. This just started...
Refrigerators and Freezer combination units have one common compressor and coolant for both units. If the refrigerator section is not getting cold I would check the following.
The cold zone is not blocked by a bag or box? The cold zone would be the coldest part of the refrigerator which vents the cold air from the freezer to the refrigerator.
Is the fan working on the refrigerator to vent the cold air to the refrigerator? You should be able to hear it when you hold the door switch.
The thermostat is not working which I have found most common is the thermistor is not registering the correct temperature causing the fan not to turn on.
Thank You for using Fixya.com
Jul 31, 2009 | Whirlpool Refrigerators
Whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Jul 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore side by side model#59652679201 freezer not working
Dear tlmassey -- did you get this problem fixed? I seem to be having the same issue.
Thanks,
Ahoward
Apr 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
FRIDGE THAWING
pull your refrig away from the wall and check to see if your compressor is running i'm willing to bet that the start relay is bad you will here a humming and then clicking noise approx every 3-5  mins. its a very easy repair get part number 8201786 from whirlpool it has detailed instructions and should only cost you 40-60 dollars for part.
Jan 22, 2009 | Whirlpool Refrigerators
Whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
107 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
