Question about Microsoft Xbox 360 Console
Gaming screen When I play games the screen has a bunch of black dots all over the place. When the xbox 360 is loading a screen where the background would normaly be black, their is a bunch of green dots that cover the screen in a honey comb stacked effect. When I play levels with lighter backgrounds the black dots are far more visible. Almost like an incomplete digital signal. Tried changing my plugs with new replacement plugs and tried going from HD to regular setting and still the dots are there. What can I do? Thanks
  • jscottintl Feb 09, 2009
    I have the same issue but it will go away after turning everything off but comes back after playing longer than 30 minutes.
  • 3 Answers
Buy a disc cleaner and only use once it will work and only cost 5-10 pounds.
Posted on Oct 07, 2008
I have a graphics problem with my xbox. this never happened until now. when i play a game, there vertical white lines and a bunch of colored dots on the screen. But though this happens when gaming the...
The specific cause is the G.P.U. losing connections from the texture mapping feeds
to the hana/ana chip set. this can be a stubborn problem because the disconnects are
on the corners of G.P.U. . R.R.o.D. is coming soon .
Recomendations
You need a solid reflow of the G.P.U. and a hardware up grade for the
X clamp . that should resolve the problem . just a reflow may not last
just google " Conformal Compression Assmbley"
If you have any questions just ask.
Rob
Nov 26, 2010 | Microsoft Xbox 360 Console
What arethe black dots appear when playing a xbox game
These "black dots" you talk abotu could be a variety of things and since you haven't given much detail it's hard for me to say.
Just double check it's not your TV or cables or any nearby electrical products causing interferance so you're certain the problem originates from your Xbox 360.
Hopefully, it's just a problem with your cable, maybe it's not plugged in right or maybe a replacement will fix it.
When I say hopefully, I mean, hopefully it's a cable fault as opposed to an Xbox 360 hardware fault. Variations of black lines or dots, or just general artifacts on screen while using your 360 usually happens prior to a hardware fault usualy concerning the GPU.
I guess it's just a waiting game for you now mate.
Just check it's not your TV or cables or any nearby electrical products causing interferance.
Nov 15, 2009 | Microsoft Xbox 360 Console
Is xbox 360 a computer?
Both, really. All consoles are types of computers, they work much like computers, but every bit of the CPU, RAM, Video, Sound capabilities are devoted specifically to playing the game you have in the system at the time.
The XBOX 360 is more unique compared to other console systems, however, since it was made by Microsoft. They engineered it so that it works more like your PC, and even WITH your PC since you can link your 360 to your PC. Also, the 360 does have other processes that it can work on in the background, such as downloading things from the Marketplace. I'm not sure how that affects the console's functionality as compared to other consoles.
Most other consoles have 0 background processes. That, coupled with the fact that all of its resources are used for ONE process/application, tends to make gaming consoles more powerful, graphically superior machines for playing games.
I would never, however, consider today's gaming consoles as mere toys. Firstly, they are very expensive and breakable. They are also high-tech gadgets. They are made so that even the younger audience can learn to interact with them, but believe it or not, these days gaming is probably just as popular, if not more-so, with the adult demographic than with the pre-10 yr old crowd. Put it this way... is this $300 piece of equipment something you'd trust in the hands of a 2 yr old?
Anyway, that's my opinion. Hope it was helpful. =)
Sep 22, 2009 | Microsoft Xbox 360 Console
Black screen with dots but everything is fine.
this is your TV Set. it needs to be bigger and more HD than the one your using.
Sep 06, 2009 | Microsoft Xbox 360 Console
Screen fills with black lines and dots when playing games
Does it ever get the Red Ring of Death? If not, it sounds like it will soon. I have lost 2 360s that way.
May 11, 2009 | Microsoft Xbox 360 Console
Xbox 360 randomely gets a black screen
Well here's the problem the towel trick. Ok the problem with the 360s for the most part is small cracks in the solder which causes a bunch of problem from rrod to this. The towel trick heats up the 360 enough to get the solder flowing again thus providing for a temporary fix. The problem is the solder goes places is shouldn't, thus towel trick ends up messing the 360 up more then it helps. My advice send it in, hopefully you still have the warrenty.
Mar 14, 2009 | Microsoft Xbox 360 Console
Xbox360 during game play screen gets vertical lines
that cd may be f'd up if so go rent a new copy and see, if no help then send xbox back to microsoft for a refurbishing process.
Feb 24, 2009 | Microsoft Xbox 360 Console
Xbox
if its less than a year old phone Microsoft customer support.
if not it could be early signs of 3 red lights
Jan 17, 2009 | Microsoft Halo 3 for Xbox 360
Black lines 1/8 of an inch apart going down my screen when playin
I had this happen a few times, then after a while it stoped working all together. In the end I was getting the E74 message code appear when I turned on my xbox 360.
You'll probley get this happen with yours soon, the E74 code means theres a problem with your visual display.
Sometimes it can be as simple as changing your HD Lead or scart lead, whatever your using. If you know someone else with a xbox try theirs.
If this doesn't work you'll have to send it off to mircosoft, it will be free if your still under warrenty, if not I think it's about £100+
Or you could go on www.cd24-7.co.uk and buy one of their DIY kits.
Hope this helps.
Jan 11, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
163 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
